rotor bolt torque (flyweel)
Started by ducatigirl100, October 02, 2015, 03:18:02 PM
ducatigirl100
Hi I' m curently working  on a 2007 s4r monster whit a testastretta engine .
I've put the flange back on the flyweel but I still have to bolt the rotor to the flyweel....
the dealer told me those bolts where torque at 13 Nm
Seriously !!!!! Graded bolt that need red locktite...... and only 13Nm  .... I serriously doubt that !!! [coffee]
To my evaluation it sould be aroud at least 70Nm
Does someone here as the torque for these bolts .... ???
ducatigirl100
I see rotor /flyweel    13
I guess it says 13 Nm ... mmmm ...
wandering
Quote from: ducatigirl100 on October 02, 2015, 03:26:30 PM
wandering
What size bolt is it?
yes, that is the correct torque, now, before doing that, go to dealer and get the upgraded bolts with  hexagonal heads instead of the T20 torx bolts you have  . . . 77253330ZF  cost should be arund $1.07ea*8
flywheel nut   270N\m with Loctite 128455 . . .
I got my source  ;D
ducatigirl100
Tanks 😊
Just to makensure where talking of red loctite on this ?
ducatigirl100
#6
Yepp!!  13Nm .... I've put the flyweel/flange/rotor  back together  and it makes sense...
last question ...
Ihas I was putting everything together in the same order that I desasemble the thing  I've notice that the #18 on the next image was the other way aroud ....
[bang]
it left me wandering    the spacer  goes what way ...?   [coffee]
Photo number 1
Or photo number 2
follow the diagram you have . . .
19 goes on 18 and 17 gives them space on large gear
ducatigirl100
Quote from: DarkMonster620 on October 03, 2015, 01:33:10 PM
tanks ...  [thumbsup]  i'll follow the diagram  photo #2 is the  whright one .. [Dolph]
pm me your email to send you link to manual
ducatigirl100
Blackout
Am I seeing this correctly? Part #17 (thin washer) does not fit inboard of the roller bearing. I re-assembled mine in this manner (after replacing the starter clutch spring) and it made a sickening screeching sound upon start up. When I disassembled it again I could see that the washer was torn up.
Anyone else done this recently? ???
2003 Ducati Monster 1000
2003 Honda CR250
2008 KTM 990 SuperDuke
Can you post a pic of the washer?
The snout of bushing #18 is supposed to go through the center hole of #17.
Standard method of assembly employs some grease to 'stick' #18 in position, so it doesn't slip down and get pinched between the snout of #18 and the timing gear.
