getting started ,, after swap
Started by drew23, December 25, 2015, 10:46:27 PM
drew23
Really more of electrical advice . swapped 900 into/from 750 ,, motor in ,, harness laid out ,,- cluster , signals , brake lights work but nothing when starter button goes in ??? whats the possibilities that I'm over looking , with the swap ?? whats the best way to ,, if parts can , be tested through the starting circuit ??  thnx
What year 900 motor, and what year 750, and which harness?
drew23
the motors a 99 , 900 . swapped out the 2001 750 . have harness for both ,,, the better condition one , the 99/900 . ,,, :-\    everything else works fine ,,, except ignition ,,, ignitors ? coils ? could be the switch ,,,,  [bang]
OK, does the motor crank, turn over and not start?
Or does it not crank?
drew23
does not . ,,,, ????   headlight , turn signals , brake lights etc. good ,,,, but nothing from start button .  >:(
If you short across the terminals of the starter solenoid, does it crank over?
drew23
HAAPY NEW YEARS !   i'll pull the plugs and try that .   ( thanx for the help with )
drew23
#7
it does ,,, so what components should be checked , and how ??  looking over wiring diagram ,,,
drew23
drew23
pouring through past post ,,, great to have available , even if time consuming
[coffee]
Quote from: drew23 on January 01, 2016, 04:16:42 PM
[coffee]
...if you want to post pics... ;)
drew23
Thnx ,,, my technical kno-how isnt much ,,  have pics on photobucket ,,, trying to upload inbetween  [img] 's  ,,, ??   Wheres , whats  "clipboard " , the left click ,, says  "copied "   ,,, to where ??
drew23
   ,,,, 3hrs gone trying to post pic ,,,  ???
On your photobucket photo, there are three small lines - click and choose the 'share' option.
Click on 'direct'.
The 'copied' message tells you the link is copied to your computer.
When typing a message here, click on the 'Insert image' button (looks like a painting), place your cursor between the two [img] thingies, right click and paste.
