Ducati SS Project
Started by Yorkie, January 15, 2016, 12:39:44 PM
Yorkie
As well as the other two Ducati's I have almost finished this one, its finished enough to use as my everyday ride.  This was originally a 750 SuperSport (1992) that I bought of a mate for £365.
After stripping it down, I needed to replace loads of bits:
I sold off all the plastics and powder coated the frame:
I found a broken carbon Monster S4 Challenge rear hump that with some work fitted over the original rear seat:
Yorkie
Yorkie
I sold off the 750SS engine and polished up the rear swing-arm all part of some mad plan:
I got hold of a carbed 900 bottom end, ready for some modification:
The only barrels and pistons I could find were from a 900ie:
With a bit of cleaning the fitted just fine.  After a few weeks I managed to get some heads.  The only down side was they were from two different bikes:
Yorkie
Yorkie
I fitted some Blackshadow discs to the front wheel:
The frame and rear sets were put in place:
Slowly but surely it started to take shape:
Again custom adjustable cam wheels were fitted to the engine:
Yorkie
Yorkie
The front end came together easily.
It started to look like a bike:
Part of the project was to make it a single sided exhaust so a bit of chopping and some really bad welding and it was done:
To top it off I managed to get my hands on this end can:
Yorkie
Yorkie
With the carbs on it was time to fit some good looking alloy intakes:
I then fitted some really good bar end indicators:
Carbon front mud guard:
The grips were wire locked in place for a little racer look:
Next it was on to the limited body work.
Yorkie
Yorkie
After a bit of glassing and some filler the rear seat cover was looking quite tidy:
The fuel tank was cleaned up and prepped:
A friend then did the top coats:
The best part for me was my custom Ducati decals, based on the Relentless energy drink writing:
I missed out some lighter bits that were put in the engine:
Yorkie
Blackout
You know your stuff. [beer]
Are you otherwise employed? This must take up a lot of time.
2003 Ducati Monster 1000
2003 Honda CR250
2008 KTM 990 SuperDuke
 [thumbsup] & +1 on that. You surely have your own workshop/business. If not you should!
Those carburettor velocity stacks are great. You make them?
How much work to match up the top end oil galleries, etc?
Cheers.
Yorkie
I fitted race pattern rear-sets for a difference:
The exhaust was so easy to fit and it soon turned out that the end can did not need any supporting brackets, so it was a really clean look:
With the body work on it starts to take shape:
Yorkie
Yorkie
Quote from: Blackout on January 15, 2016, 02:08:18 PM
Total amateur mate, I do the work on Saturdays only.  Fully employed and this is a hobby.
Yorkie
Yorkie
Quote from: koko64 on January 15, 2016, 02:20:25 PM
How work to match up the top end oil galleries, etc?
Cheers.
The lock-up is a mates, he charges me nothing for the space or his time, and he has the skills.  He has all the bits made (by another friend) and sells them here:
http://www.madasl.co.uk/products.php
All the engine bits are plug and play really, so just a lot of cleaning.
Yorkie
Yorkie
Nearly at the end!
The rear seat cover had to look right, so a lot of playing around with how it sits was essential:
With the exhaust tighter to the swing-arm it was looking good (well I think anyway):
The headers were covered in exhaust wrap to tidy it up:
The very small rear light and number plate hanger had to fit nicely under the seat:
Yorkie
Yorkie
The loom was a nightmare and I ended up cutting out about 3 meters of wire to tidy it up:
A lot of after market stuff was fitted to make it right for me, I hid the electrics to the rear in a plastic pipe to keep the lines clean:
Custom alloy top yoke:
The last bits of wiring were almost done:
I cut some flat carbon sheeting to mount my Acewell speedo on:
All wired up:
All done:
Yorkie
Yorkie
Here's a few more pictures:
My replacement oil pressure switch:
The bike runs the minimum of electrics and bodywork, no idiot lights and all additional body work removed.
Hope you like it.
Yorkie
Mhanis
That is a heck of a lot of work done there, well done!
For no reason other than curiosity, how long from start to finish?
Mark
Pete Townshend
