January 01, 2025, 09:01:46 AM
m1000s ie aftermarket headers available?
Topic: m1000s ie aftermarket headers available? (Read 1659 times)
Ohm3d
March 21, 2016, 07:18:02 PM »
I was looking at my exhaust when I was working on my bike this past weekend and noticed how the oem header/x-collector looks like it would restrict flow a lot. Is there aftermarket options for this bike? It seems there are only slip ons available, which my bike already came with. I saw someone post "spaghetti header" for s4 in this section which is same era of bike, but not a match in terms of engine. Bike has a ds1000 motor amd dual sided swing arm so options seem pretty slim.
Online
Re: m1000s ie aftermarket headers available?
March 21, 2016, 07:29:00 PM »
Pretty sure you will need to scour the used market, never was much as far as I know. An alternative to get some flow is cut open the crossover and modify. Needless to say, this will not help with cornering clearance.
Feral 859
March 21, 2016, 08:25:21 PM »
http://www.stradafab.net/exhausts/
Ohm3d
March 21, 2016, 10:33:56 PM »
Awesome.... so stock it stays I guess. Not spending 2 grand on an exhaust.
March 21, 2016, 11:57:30 PM »
The oem headers are reportedly good for 90 odd hp. I have seen some crossovers opened up but was once told not to open them too much.
I had a 900 Superlight that had one channel each side opened not all four.
Last Edit: March 22, 2016, 12:00:23 AM by koko64
bshinn
March 22, 2016, 05:09:50 PM »
I'm in the market for a stock M1000Sie header/collector. If anyone has a line on one please let me know.
Thanks
Düb Lüv
ASE master internet mechanic
March 24, 2016, 06:55:16 PM »
Quote from: bshinn on March 22, 2016, 05:09:50 PM
Thanks
i may have one from my 03 1000ds monster. ill have to check the condition.
Building, building, building
bshinn
March 25, 2016, 07:26:31 AM »
Thank you Sir!
Ohm3d
August 20, 2016, 07:55:10 AM »
Im bringing this back from the dead as im about to build my motor. Im doing a 4mm over bore, 11.5:1 cr pistals, dp cams, headwork, new bearings... etc... so now with all this extra jam, i think the stock.header is gonna be restrictive
Anyone got any recommendations?
August 20, 2016, 02:49:28 PM »
I would enquire with our sponsors regarding brands like Spark, Sil Moto, Arrow, etc. That would be my first attempt.
I dont know if Termignoni made one, but if they did maybe a dealer might be able to track down NOS?
Directly contacting Staintune in Australia might be worth a try too. Although an older model pipe they have all the jugs and may build on request.
