October 01, 2024, 06:25:05 PM
m900 clutch slave 1995 replace w early 2000 slave need 8mm ballbearing?
Topic: m900 clutch slave 1995 replace w early 2000 slave need 8mm ballbearing? (Read 741 times)
paul rockwell
May 16, 2016, 09:02:28 AM »
My slave cylinder started leaking and my clutch gave out. I went to a cycle shop and bought a slave cylinder off an early 2000s monster. My bike is a 1995 monster 900m. I put the slave on and bled. The clutch wont engage. I did research and read that pre 2000 bikes have actuator rod that doesnt stick out as far and that adding a 8mm ball bearing will cure this problem? Is this true? I dont want to mess up slave if I have to return it.
Re: m900 clutch slave 1995 replace w early 2000 slave need 8mm ballbearing?
May 16, 2016, 09:07:42 AM »
There were some aftermarket slaves that required the use of a ball bearing on some bikes, but 8mm sounds too big. I don't think it will fit inn the slave piston. I've also seen the ball wear into the piston.
You could get the longer pushrod.
paul rockwell
May 16, 2016, 11:48:26 AM »
Thank you
May 16, 2016, 01:08:35 PM »
The typical spacers are 8mm diameter, 10mm long.
Some are cupped on one end to fit the round ended pushrods.
May 16, 2016, 01:32:28 PM »
Quote from: Speeddog on May 16, 2016, 01:08:35 PM
Shows you where thought will get you.
