October 01, 2024, 10:19:08 PM
GBRacing covers & reverse shift
Topic: GBRacing covers & reverse shift (Read 995 times)
IdZer0
BE
May 18, 2016, 01:22:58 AM »
Hi,
So I just recently decide to try out reverse shift and now I bought GBRacing engine protection but it turns out you can't get the shift lever at the right angle (90° vs the rod) once the protection is in place. Do you think this angle is still OK:
replaced by 2011 848 EVO
Mhanis
Re: GBRacing covers & reverse shift
May 18, 2016, 02:42:43 AM »
Does it work?
Mark
Pete Townshend
IdZer0
BE
May 18, 2016, 07:07:39 AM »
I haven't tried riding it yet, it seems to work. I'm worried about mis-shifts etc. specially at the track.
S2R 800 '07
May 18, 2016, 08:32:54 AM »
Try it.
If it doesn't quite work, modify the cover?
May 18, 2016, 10:40:31 AM »
Quote from: stopintime on May 18, 2016, 08:32:54 AM
Try it.
It's not the cover. Looks like if he adjusts it more the linkage will hit the frame.
S2R 800 '07
May 18, 2016, 11:01:39 AM »
Quote from: NAKID on May 18, 2016, 10:40:31 AM
That might be so, but the cover was the issue?
May 18, 2016, 11:32:14 AM »
Quote from: stopintime on May 18, 2016, 11:01:39 AM
I see what you're saying now.
Another possible solution is going with a dedicated reverse shifter. Eliminate the slop of the linkage altogether.
