Hankering for a 900 Project
Started by koko64, May 24, 2016, 03:41:33 PM
scaudill
Yes, that's correct, I also have the Delorto manual. [thumbsup]
I was wanting to try more affordable carbs. The TMs are alot of bang for the buck. 40 deg is a lot for what is a side draft carb. I wonder how the float system copes.
Quote from: greenmonster on May 25, 2016, 05:05:03 AM
Just got a MTS 1100 and really love the tourqier engine, nothing wrong w a modded 900 though.
Go w the SL project, bet it`s more interesting for you w the carbs etc.
I think Ducati had a design peak first half of the 90`s.
One of my favourites:
Let me give you a push in the right direction [evil]  ;D:
http://www.ebay.it/itm/Termignoni-silenziatori-corsa-alto-Ducati-900-SS-1991-96-/112006675517?hash=item1a141e3c3d
Hens teeth up for grabs again.... [thumbsup]
Very nice SS.
The 1100 in your MTS is a great motor too .
greenmonster
Nope, Compralo Subito=Buy it now.
Catch it while you can. [evil] ;)
M900 -97
MTS 1100s  -07
I put my buddy with a 1992 Superlight onto it. [thumbsup] Got kids University fees, otherwise I would have snapped them up.
Two of my kids are looking at buying a 92 400 SS. If they do I guess in time I could look for a 900 motor [evil].
Poor man's flatslides ;D. No accelerator pump. But you get chokes (enrichening circuit) for which you can buy extended cables.
You gotta run 'em horizontalish on short manifolds. That's about $500 Aussie Pesos for a pair with matching throttle with 2 into 1 cables. You need pod filters and cut n shut oem manifolds or get Mikuni or Malossi manifolds. The Mikuni rubber manifolds are quite affordable. You could run a Mikuni pulse pump with dual outlet.
Do those come with (or can they be bought) a 4-stroke style emulsion tube (I call 'em a needle jet)?
These are the 4 stroke versions but the TMX is the two banger version. Im guessing the needle jet is quite different. I'd want to polish the bell mouth however.
Well, its back to Plan A. Long manifold polished pearl M900. It will at least be cheaper with ported oem carbs
Kids have selected the Monster path after much consideration of Ducati options and even small capacity Motards.
A Monster it shall be.
I'll have to wait for a customer with an SS for plan B.
What I have so far.
Nichols engine to frame bolts.
Spare manifolds to port.
Ported BDST38 carbs.
DJ Jet kit and spare Mikuni jets.
Airbox and modified velocity stacks. I'll "enlarge" it and use a K&N Pani filter on top (fits better than the DU0900).
Mikuni quick action throttle with single cable operation.
Motowheels oil filler cap. :D
Alloy clutch basket and Vee Two billet hub. Alloy friction plate kit.
Just need motor and hi comp pistons. [laugh]
Kopfjäger
