April 27, 2024, 01:33:29 AM
$hit... Hoping its not the transmission... HELP PLEASE
5
Topic: $hit... Hoping its not the transmission... HELP PLEASE (Read 12977 times)
Re: $hit... Hoping its not the transmission... HELP PLEASE
Reply #30 on:
June 13, 2016, 11:36:15 AM »
Can you take another picture , like the second one, but straight on?
clubhousemotorsports
Reply #31 on:
June 14, 2016, 06:26:58 AM »
For alignment also make sure it is in Neutral, it is not in the pictures.
You should be able to manually rotate the shift drum and get it there, turn the drum counter clockwise while rocking the countershaft back and forth to align the dogs.
Last Edit: June 14, 2016, 06:29:50 AM by clubhousemotorsports
lipski24
Reply #32 on:
June 15, 2016, 07:17:45 AM »
Shift drum..? Sorry, i am not up to speed with yall yet. Haha!
Yes I can take another picture like that. Any other pictures I should take??? So can I remove the flywheel without screwing up timing or anything? Sorry for my lack of knowledge on these bikes guys... I appreciate your patience!
Reply #33 on:
June 15, 2016, 07:27:18 AM »
The shift drum is the round thing at the top right with the pegs that the arm turns
lipski24
Reply #34 on:
June 18, 2016, 04:56:03 PM »
https://imgur.com/a/TEnCi
So I have been messing with it and I am still confused as to what happened..
How do I get the flywheel off without screwing anything up? And then what do I do to adjust whatever I need to..?
Thank you for your patience... I'm very new to this unfortunately, but I really want to learn.
Last Edit: June 18, 2016, 05:09:14 PM by lipski24
Reply #35 on:
June 19, 2016, 02:53:15 AM »
Was the bike in neutral?
lipski24
Reply #36 on:
June 19, 2016, 07:20:26 AM »
While I took the pictures yes..
BK_856er
2007 M695; 2004 749s
Reply #37 on:
June 19, 2016, 08:17:41 AM »
OP, did you read and study the linked threads? Have you sourced at least one electronic or printed manual? Do you have the proper tools to do the job? The shifter adjustment is tricky to describe with words. There is a newish tool to get the harpoon close to perfect without a lot of judgment. Here's another set of pics to look at - don't worry the shifter mechanisms are all the same:
http://www.europeancycleservices.com/project-bikes/jasons-848/
BK
lipski24
Reply #38 on:
June 19, 2016, 02:53:30 PM »
I need the adjustment tool. I have been looking at the owners manual online and the parts one. It hasn't helped all that much.. Could you point me in the direction of the adjustment tool your talking about?
Reply #39 on:
June 19, 2016, 03:07:46 PM »
The shift linkage needs adjusting. There is a locknut and eccentric peg behind the flywheel.
Flywheel has to come off.
This job might be beyond the capabilities of your tool box.
lipski24
Reply #40 on:
June 19, 2016, 04:00:25 PM »
I would be willing to buy the tools I need.. I just need someone to give me a link to them. I will need yalls help on it, but I am confident I can handle it as long as its just the adjustment.
Dirty Duc
I'd rather be an anti-
Reply #41 on:
June 19, 2016, 05:16:59 PM »
https://www.google.com/?gws_rd=ssl#q=ducati+gear+selector+adjustment+tool&tbm=vid
The first video on my search...
And the part number for the tool is in the first post in BK856er's thread.
Ducatis on the Salt
lipski24
Reply #42 on:
June 19, 2016, 08:34:46 PM »
That should help me quite a bit. I will buy the tool, then give it a shot. I will start a new thread for everything else. Thanks guys, and please throw some words on the new thread when I start to do the actual adjustment!
Dirty Duc
Reply #43 on:
June 19, 2016, 09:46:38 PM »
I'm not trying to discourage you, I'm attempting to instill a problem-solving attitude. There''s an awful lot of info out there, don't expect others to find it for you. You have to evaluate all advice you get from the internet with the same filter. This is just a better place to start than most.
Ducatis on the Salt
Reply #44 on:
June 20, 2016, 02:23:48 AM »
Quote from: lipski24 on June 19, 2016, 08:34:46 PM
No need for a new thread.
This one will work fine.
5
