'04 S4R - feels a bit rough on the throttle (and clumsy) compared to my 996
Started by segascott, June 03, 2016, 12:55:23 AM
segascott
Howdy folks - new to the monster realm, just picked up an '04 S4R, which I thought should have a lot of similarity (engine-wise) to my '00 996.
The previous owner of my 996 was a track day junkie and set it up pretty well - it has an ultimap chip, single injector conversion, and arrow exhaust with stock filters (no intake restrictors). It's really smooth and predictable when you crack open the throttle, and that smoothness continues as you go through the rev range.
The '04 S4R in comparison is completely stock right down to the udder, beer tray and evap canister. Though newer and with fewer miles than my 996, it feels clumsy when you crack open the throttle and just doesn't feel as smooth (or strong!) as you get on the revs.
i'm hoping some of you monster experts out there might be able to chime in: what's the S4R equivalent of the 996's ultimap/single-injector/pipe combo? I'm loving the ergos and style of the S4R, but really wish it felt as smooth as the 996...
thanks folks,
Scott in socal
Don't worry, you're in the right place. Folks with tuning expertise for your bike will chime in soon. I'm not one of them ;D.
I am no tuner but, you have have apples, altought 2 different kind of apples . . . And you have said it yourself:
996=tuned and modifyed
S4R=bone stock
Might be same engine but, 2 different ECUs . . .
Maybe copy-paste this on the Acc-Mod thread
S4R vs '00 996:
Heads are slightly different, lower exhaust cam position
Intake cam is different, slightly less duration, closing 10 degrees earlier
Airbox is totally different
Exhaust is very different
ECU is different
segascott
Quote from: DarkMonster620 on June 03, 2016, 07:28:23 AM
S4R=bone stock
Hey there, thanks for the reply. I was probably babbling too much in my post... but I was hoping someone around here with S4R knowledge might also have a little 996 experience to be able to recommend a similar setup. Is it uncool to cross post this to acc-mod? Here's the pertinent question that was buried in my post:
Quotewhat's the S4R equivalent of the 996's ultimap/single-injector/pipe combo?
Quote from: segascott on June 03, 2016, 10:04:34 AM
No problem . .. to answer the "buried" question, one[996] was custom mapped, the Ducati Performance map might help you a little, but, for more or a closer feeling to the 996, you would have to have the bike dyno tuned with a custom map
segascott
Quote from: Speeddog on June 03, 2016, 09:57:55 AM
S4R vs '00 996:
ECU is different
hey, thanks - some good info here. it was pretty simple with the 996, a lot of folks knew what the standard "make it run gooder" setup was... seems to be a lot more options with the S4R. Just started reviewing that closed loop thread over in mod/acc, looks like I have a lot of catchup.
Closed loop thread is very good, but not really relevant to your bike, as it's open loop.
There's a good bit of stuff that can be done to make your bike run better.
First off, is the maintenance up to date, specifically valve clearances?
blalor
I've been having the same problem with my S2R 1000.  Different bike, I know, but the symptoms were similar.  I just got home from Rexxer's shop where I had the throttle bodies baselined (synced and working as a team, apparently), and the ECU reflashed.  My bike's also bone stock.  It was impossible to ride smoothly at around-town speeds, and it would surge and buck always.  The jury's still out, but my initial impression is that it is MUCH more controllable when cracking open the throttle from fully-closed, and runs more smoothly, now.  Something to consider.  The ECU flash was $300.
Exhaust system (udder removal mid-pipe) and a set of performance cans coupled with a ECU reflash to the Ducati Performance specs is a fantastic start.
+1 on Speeddog's comments about maintenance.  The 1 thing I wanted to add to Speeddog's list of things to check: The throttle bodies grow a thin (at first) carbon ring around where the blades rest at idle.  This *needs* to be cleaned and kept clean to get crisp throttle and off-idle response.
segascott
Thanks, Speeddog + duck-stew! I definitely want to do the cat removal, though I guess I'm one of the weird ones that actually likes the look of the stock cans (is it just me?). Wonder if that DP ECU reflash will still play nice with the stock cans...
...but if the DP reflash gives that smooth transition when you just crack open the throttle, I'm all for it!
Speeddog, the previous owner had the valve check done fairly recently. That being said, I've noticed some different sloppy things that the shop did (some bolts not tightened properly, clutch fluid wasn't flushed/bled even though they charged him for it, etc) so I think I'll need to go in there and double check.
Stew, I'll definitely check out the throttle bodies - been looking forward to tearing down the monster a bit.
Blalor: just what I wanted to hear - did you get the DP reflash? $300 sounds damn cheap if it cures the part-throttle fueling!
blalor
No, not a DP reflash. The tune is more-or-less specific to my bike. Disable the O2 sensors, "make it run better". I worked with David Lilliard (owner of Redline and Rexxer) and told him what I wanted. He maintains that the throttle bodies are never really set up correctly at the factory; I think the 1.5 hours of labor is approximately what's described here. I think that's probably responsible for the smoother running engine and maybe some of the throttle control off-idle. The flash is probably responsible for getting rid of the surging, bucking, and hesitation. Again, I've got like 75 miles on the bike since doing it, but I'm quite optimistic.
I had assumed you had gone to Redline . ..  you described the procedure David goes thru when working on bikes . . . he has a dyno, that is the best way to tune a bike . . .
segascott
Quote from: blalor on June 03, 2016, 06:56:47 PM
Ah, gotcha - good to know. I'll do some reading up on the Rexxer tunes... I'll look up the procedure for syncing the throttle bodies as well, guessing it won't be much harder than syncing up carbs, right? Anyway, your description sounds great - that's definitely how I'd like the S4R to feel...
S21FOLGORE
I think it is normal for a US model bone stock earlier (non testa) S4R to do bucking bronco at lower rpm, slower speed range, not running smoothly.
What worked for me, is
1 Arrow full exhaust system
2 open air box lid (the top of the air box lid is cut open, a la DP style)
3 flashed, custom mapped ECU
1,2,3, done all at the same time.
Dyno printout (yeah, it doesn't show you off idle to 3000 rpm smoothness, but I thought you might be interested.)
And then, after the regulator / rectifier died (and I pushed the bike for about a mile and a half, about an hour ...)
I relocated the R/R, which required removing the stock PCV (Positive Crankcase Venting) system hosing, I disconnect the pipe to the air box (the air box hole is plugged) and extended the vent hose all the way to behind the license plate.
This, also made noticeable difference. I didn't bother to check the difference on the dyno, though.(in theory, I should be loosing a little bit of HP). I felt like this smoothed out lower end  even more.
Then, I lowered the final drive ratio a little bit.
So, I suggest you invest in ...
Free flowing exhaust, full system, NOT slip-on.
Cut down the air box lid. (otherwise, stock box would be too restrictive)
Reflash and custom map ECU
All three at the same time.
And then, ...
About Regulator / Rectifier problem on these bikes
I suggest you search on this forum about this and read by yourself, if you have enough time.
To cut it short, sooner or later your R/R WILL fail if you keep the stock design.
So, you have two choices. Wait until it fails (then you will get stranded and will have to buy a new R/R), or relocated the R/R  now (then, it will prolong the life time span tremendously (R/R's, not yours).
Unfortunately, relocating the R/R into the “right place” requires removal of the stock oil catch tank.
So, when you do this, you are looking at two mods at the same time. Reloacating R/R, and disconnecting the PCV system.
http://www.ducatimonsterforum.org/index.php?topic=57299.0
About disconnecting the PCV system
This topic has been covered in many places (not just this forum), and people have different opinion.
I will come back later and explain about mine ( I will have to go to work, don't have enough time right now).
For now, I leave you something to read.
http://www.ducati-upnorth.com/tech/breather.php
http://www.ducatimonsterforum.org/index.php?topic=2469.0
http://www.ducatimonsterforum.org/index.php?topic=49770.0
http://www.ducati.ms/forums/57-supersport/431857-importance-crankcase-breather.html
