November 28, 2024, 03:47:29 AM *
Author Topic: SV650 switchgear on M695  (Read 2784 times)
cencalal
« on: June 23, 2016, 03:45:39 PM »
This is a test of photo posting...
cencalal
« Reply #1 on: June 23, 2016, 03:53:07 PM »
Sorry - I've posted photos from Photobucket here before, but can't recall how...
The post in FAQS is no help - Photobucket doesn't look anything like what is shown.
« Reply #2 on: June 23, 2016, 03:56:57 PM »
You need to add a link in between the image tags. In your first post there is no link.
Feral 859
« Reply #3 on: June 23, 2016, 03:59:10 PM »
Well, that didn't work.  How can I delete this post?  Huh?
Click 'remove' to the right of your post, but you can't delete the thread.  bang head
S2R 800 '07
« Reply #4 on: June 23, 2016, 04:34:55 PM »
Three lines top left corner of the picture -> Share -> click on "Direct" (=auto copy)
Paste between the tabs which appear when you click the image/scenery button here.
cencalal
« Reply #5 on: June 23, 2016, 05:11:14 PM »
cencalal
« Reply #6 on: June 23, 2016, 06:00:00 PM »
Thanks all!   Roll Eyes  That's the after photo - here's the before:
[/URL]
I had asked in a previous post about the Panigale switchgear...
http://www.ducatimonsterforum.org/index.php?topic=73520.0
...and when that seemed like more trouble and expense than I was up for, I looked for an alternative.  Didn't have to look too far, as I have an SV650 which has these switches, and a few measurements confirmed that they would give me the better turning radius I was after, and the better looks too.  Found a nice clean set on ebuy for $35 and was able to solder them to the M695 wires without melting anything. (This required a few beers.) The Mster had a separate throttle with larger diameter cable pulleys and the SV is a one piece throttle/switch module...
...so I found a throttle body pulley of the matching 34mm diameter (most are this diameter - don't know what this one came from) and adapted it.  I made this simple bracket to mount the shortened SV throttle cable:
I was able to eliminate the fast idle cable and it's bracket because with the FatDuc oxygen sensor manipulator there's no need - it idles and runs fine when cold.
« Last Edit: June 24, 2016, 08:53:09 PM by cencalal » Logged
Feral 859
« Reply #7 on: June 23, 2016, 06:19:19 PM »
Look to the right of the post. You can modify, or remove
cencalal
« Reply #8 on: June 23, 2016, 06:36:54 PM »
Thanks.  I knew that - I was just hoping you'd answer so I could see the photo of the blonde babe again.   Kiss
Feral 859
« Reply #9 on: June 23, 2016, 06:41:10 PM »
 Cheesy
cencalal
« Reply #10 on: June 28, 2016, 10:10:50 PM »
Why would my photos be gone?  There are only boxes with a question mark in a blue square...
Feral 859
« Reply #11 on: June 28, 2016, 10:23:56 PM »
Photobucket does maintenance from time to time and pics will disappear then return.
cencalal
« Reply #12 on: June 28, 2016, 10:56:32 PM »
I see - thanks again.  A guy can learn a lot on this forum - even if it's not about motorcycles.
Apparently nobody cares about my switches anyway... Sad
Feral 859
« Reply #13 on: June 28, 2016, 11:01:35 PM »
As long as you didn't delete them from your album, they should regenerate. Oh and it doesn't matter if anyone other than you like them or not.  Wink
Charlie98
Marveling at my
McKinney, TX
« Reply #14 on: June 29, 2016, 04:44:24 AM »
Actually, they are pretty snappy looking... nice job, particularly with the cable fab at the throttle body.  I always liked my Honda switches, but it's a nogo with my 796 because of the data toggle.
Dennis
2013 M796 ABS
