June 25, 2022, 06:04:46 PM
DFWM
Ceramic Coating?
Topic: Ceramic Coating? (Read 10099 times)
Cher
Mostly Harmless
Ceramic Coating?
August 11, 2016, 06:24:33 PM »
Anyone have first-hand experience with ceramic coated exhaust pipes? Does the coating make a real noticeable difference or is it just wishful thinking?
Pinocchio
Unsung
Re: Ceramic Coating?
August 12, 2016, 07:55:42 AM »
You'd have to dyno the bike with the intent of remapping the ECU to take advantage of the "exhaust port scouring" property that ceramic coating provides, otherwise you'll just get more lean popping on deceleration. You might also notice less radiant heat from the header in heavy traffic, but without remapping, that's about it.
1969 Scrambler (450 “Jupiter”)
2005 MTS 1000DS
2007 S4RS
2010 MTS 1200S Touring
, 2018 Monster 1200R, 2021 Monster 937+
Cher
Mostly Harmless
August 12, 2016, 05:22:50 PM »
My intent with ceramic coating would be to reduce the radiant heat from the exhaust system… especially the rear cylinder that has the header right under the seat. I'm not concerned about potential performance gains, although, MORE POWER is always better
I'm beginning to realize the R-spec 999 must have a useable riding "season" of about four days in mid-February when it's about 28 degrees or so. Oh well. I like February…
Last Edit: August 12, 2016, 05:25:24 PM by Cher
swanny
August 12, 2016, 06:26:16 PM »
How about wrapping the exhaust?
Swanny
2011 848 EVO Track Bike
2015 Hypermotard SP
muskrat
August 13, 2016, 03:36:25 AM »
I'm told it helps and I also don't think you need more power.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Cher
Mostly Harmless
August 13, 2016, 05:53:23 AM »
Quote from: swanny on August 12, 2016, 06:26:16 PM
Swanny
Does that help reduce the heat on the rider? Silly question I know but having read just enough technical stuff to be dangerous, as I understand it, engines perform better *to a point* if they retain some heat in the exhaust system. Turbochargers get heat blankets, etc. Unclear if it reduces the ambient heat in the engine compartment/inside bike fairings.
Thanks for the replies.
swanny
August 13, 2016, 06:19:19 AM »
Quote from: Cher on August 13, 2016, 05:53:23 AM
I would think so since the heat is coming from the inside of the pipes...but I am no expert!
Swanny
2015 Hypermotard SP
Cher
Mostly Harmless
August 14, 2016, 01:57:02 PM »
Going with the heat wrap of the rear cylinder header and S-pipe for now.
Took the bike out this morning at 8 am when it was about 78 degrees. No worries. Headed home when it hit 85 at 10:00. Just starting to get too hot to ride… Come on February
Charlie98
Marveling at my
McKinney, TX
August 17, 2016, 05:56:40 AM »
I rode my 796 a little in the last 2 weeks (95-100F) and setting at lights was hell (almost quite literally, given the heat.) I've considered ceramic coating as well, but also wondered about how effective thermal wrap would be...
Anyone know someone in the DFW area that does ceramic? I'd like to at least get an idea of what it costs...
Dennis
2013 M796 ABS
Pinocchio
Unsung
August 17, 2016, 07:04:19 PM »
I have used Quality Powder Coating on Forms Dr. In Carrollton, but any powder coating place should do ceramic coating. Cost was $250 with a week turnaround time, but it's been a minute since that job was done.
BTW, I got aluminized silver for looks, but flat black is supposed to have better heat-holding properties.
2005 MTS 1000DS
2007 S4RS
Cher
Mostly Harmless
August 27, 2016, 02:50:33 PM »
OK, so never mind on the heat wrap. My garage is 110 degrees… Can't "work" in that!
Having the pipes ceramic coated
August 27, 2016, 08:21:11 PM »
I've done a couple sets of customer's pipes in the satin black.
Looks good, and the vendor said it's real-world friendly, as opposed to the flat or gloss.
Cher
Mostly Harmless
August 28, 2016, 03:36:47 AM »
Quote from: Speeddog on August 27, 2016, 08:21:11 PM
Thanks. I originally thought silver would work OK, but I'll go with Satin Black then.
Mhanis
August 29, 2016, 02:38:41 AM »
Where are you having it done? This is something I have always been curious about but never seriously enough to look into it.
Mark
Pete Townshend
2009 M1100 67,000+ miles
2015 Suzuki TU250X 13,000+ miles
Charlie98
Marveling at my
McKinney, TX
Reply #14 on:
August 31, 2016, 05:08:20 AM »
Didn't happen without pictures!!!
Dennis
2013 M796 ABS
=> Remembering our friends...in Memorium
