January 21, 2025, 07:04:18 PM *
News: Please Help
Author Topic: Strange "whirring" sound from front brakes  (Read 1042 times)
shub1971
« on: October 05, 2016, 09:11:49 AM »
Hi
So my '12 M1100EVO has around 3,800 miles on it and just in the last few days it has developed a weird sound/feel to the front brakes. This occurs under heavy braking right before the bike comes to a stop. No issues at speed. It sounds and feels a little bit like when the rubber on bicycle brakes is old and you brake hard. The best description I can give is a whirring sound with some vibration. The brakes work fine otherwise - stops on a dime.
Any ideas what this could be? At first I thought it could be the pads, but 3,800 miles seems like a premature death to me  bang head
« Reply #1 on: October 05, 2016, 09:23:39 AM »
Drilled rotors?  Likely the holes passing the edge of the pads.  My M750 does it and it's got the single drilled iron rotor.
JM
« Last Edit: October 05, 2016, 09:25:13 AM by the_Journeyman » Logged
shub1971
« Reply #2 on: October 05, 2016, 09:29:23 AM »
Yes, it has drilled rotors. Thanks! So, normal, not a safety concern?
MadDuck
The anti-
« Reply #3 on: October 05, 2016, 09:51:52 AM »
Doubtful that it is a safety concern. My Ducati Superbikes both did that at times. My 1290 SDR does it now & then too, even after replacing the front discs. I'm going to flush the brake fluid and see if that helps. A bit annoying but not a performance problem.
shub1971
« Reply #4 on: October 05, 2016, 10:02:19 AM »
Thanks guys!
