Waste of money .....
Started by MonsterHPD, December 09, 2016, 08:30:02 AM
MonsterHPD
Not directly Ductati releated, but I think interesting anyway as a reference; in the sept/oct 2019 issue of Race Engine Technology magazine, there is an article about the White Alligator Racing Suzuki pro-stock drag bike, with a 2V Suzuki-based Vance and Hines motor; bore 89 mm / displacement 1851 cc, valve included angle 52°. Valve sizes not disclosed, but with those basic engine dimensions they can't be too far off Duc-relevant valve sizes.
The builder claims a min valve-to-valve clearance of 0.03" / 0.762 mm on overlap. The motor is a dual cam with a cam chain or that "allows for about 5° of relative movement in backlash between the rotating parts" (presumably crank °)
I find this pretty brave for an engine that is revved to to 14000 rpm and claimed safe to 14400 rpm ..... but it seems to work.
89mm bore by roughly 74mm stroke.
So M750-ish bore with a really long stroke.
14.4k rpm yikes!
I'm sure quite impressive valve springs, accompanied by a frighteningly large box of end-of-life springs.
0.030" is very close.
Remarkable.
Impressive. Must be Ti valves and tolerances less "than a bee's dick" as we say down here.
The saying, "the correct spec is what let's you sleep at night" applies here ;D
MonsterHPD
Quote from: koko64 on January 10, 2020, 10:10:19 AM
Interesting. When  lived in Stuttgart I learned a german / schwabian expression, "muckasäckle", referring to the genitals of a male mosqito and meaning an insignificant amount ....
Serms some concepts are similiar across  the world :-)
MonsterHPD
Well,
I consider myself finished with the porting job, incredible how much time one can waste (?) on something like this. The ports are now about as good as I can make them given my plan and my knowledge. If I have really improved something, only a ride and a trip to the Dyno can tell.
2020-01-15 16.32.39 by torbjörn bergström, on Flickr
2020-01-15 18.05.06 by torbjörn bergström, on Flickr
I will have a pro do the valves and valve seats, then it will all go back together.
Coming back to the clutch, which I will also want to improve before the riding season starts. As I remember the clutch, and the way it looks on the spare parts diagram, it's a perfectly normal clutch (mine has no slip / servo function).  To improve it, I would have started by looking for some stronger springs as a start, but I may be missing something?
pepeducat
For the cylinder heads it's good but you can "clean" the exhaust side too and for the clutch already puts new springs
MonsterHPD
Quote from: stopintime on December 09, 2019, 01:38:53 PM
Oh no, no, no  [thumbsdown] Two broken clutches (large springs in the primary driven gear) which could have ended much much worse. Good idea, lousy engineering and even worse: a factory that won't realize/admit it. They have the same shit in Panigales.
I have a 750 clutch. More grabby, but that can be helped by grinding 10-15 grooves in the steels, in a fan pattern. The 696 clutch also fit (also without the springs).
Coming back to the clutch again.... I've taken the clutch plates out, and just as a couple of years ago when it was slipping badly, the plates look perfect, though I have not measured them.
I did take a look at the clutch basket and primary drive, since earlier I've not thought about it. I suppose this is what you mean, Lars:
2020-01-16 16.35.37 by torbjörn bergström, on Flickr
Presumably, the split hear and springs are there to eliminate backlash / reduce noice?
What happened to your clutches, and are the 750 / 696 clutches a straight swap onto the 800 motor?
Kind regards,
Torbjörn.
The dual mass (spring loaded) primary drive gear is known to fail - often with very bad results.
The basket on an 800 is, I assume/probably, as on mine, spring loaded - also a good idea catastrophically executed.
The drive gear pairs from 620, 750, 696 are not made with these springs and a more robust alternative.
MonsterHPD
Quote from: stopintime on January 16, 2020, 11:01:06 AM
OK, thank you very much. I'll start the search :-)
Remember that it's important they stay the original pair (for smooth and quiet meshing), so buy a pair from a trusted seller.
MonsterHPD
I think a dry clutch conversion would a be a bit over the top right now :-)
This clutch from a 696 should do the trick, I hope, from the same motor:
20200118_155803 by torbjörn bergström, on Flickr
Now I just have to figure out how to get the primary gear on the 800 off, seems the I need some kind of a 4-pronged castellated socket ....
The driven gear (basket) on a table. Roll the drive gear over it. Not completely dry - at least a tiny amount of oil. The sound should be very low, smooth, delicious, soothing, relaxing - making a mechanic happy. Any kind of rubbing, rumbling, resistance could mean they're not a pair.
