Stator side case cover compatibility
Started by bdfinally, April 02, 2017, 02:33:06 PM
bdfinally
It's a '00 M750 Dark. What yrs & model can I use to expand my fleebay search?
Guess who forgot about the hidden bolt behind the slave cylinder rubber grommet?
'00 M750 is 3-ph charging and carbie.
AFAIK, any '98 and later carbie motor would use the same cover, so '98-'01 M400, M600, M750 and '98-'99 M900.
I'm pretty sure all '98 -'08 air-cooled ie model covers would work if you fashion a blockoff plate for where the rpm trigger goes.
bdfinally
I've checked part numbers for 600, 620, 01 M750, SS750 and they all have a different parts number. Looking at the diagrams I see only one difference, something called the "gearbox pin bush"
bdfinally
bdfinally
Ducati probably decided the bushing was unnecessary, and to let the shaft ride in the aluminum case.
Check part #'s on the shaft.
bdfinally
bdfinally
DP, if your talking about #26
they're the same across the 00M750, 00SS750, 01M600, 01M750 & M750D
Which means all the cases you pictured should fit.
As Speeddog said, if you can make a block off plate for the later timing sensor, you can expand your choices.
bdfinally
Cool!
I still can't believe on the third time I've had that cover off, I forgot about the bolt [bang]. Could I have screwed anything else up by cranking that hard on it?
The threads that the hidden bolt go into may not have been too happy about it.
bdfinally
Switched to stainless steel bolts about a decade ago too. You don't think puller did anything at that contact point?
bdfinally
Thanks guys [beer]. Last question found a newish looking one across the pond in England that looks great and is reasonable price. How long do you think to get to east coast and through customs?
