03 monster 620
Started by jcolg1, May 29, 2017, 11:06:58 AM
jcolg1
Hey guys, looking at a 03 monster 620 for sale for $900 but has some work that needs to be done. Dent in left side of tank, muffler scraped up left side (bike was dropped), needs new chain and battery. The main problem is there's rust in the tank and needs new fuel pump. There's 7000 miles on it. Is this worth the buy for the problems/repairs it needs or should I just pass? Any help is appreciated.
Thanks
Depends on how much of the work you can do yourself.
jcolg1
Quote from: Speeddog on May 29, 2017, 11:32:10 AM
I can do battery, chain, and basic maintenance myself. I'm more concerned about the tank issue. If thats going to run me too much money where it doesn't make the bike worth it also not to mention if this could lead to other serious issues down the road. Or is it a common issue because they didn't switch the tanks to plastic tin a year or two after.
Does the bike run?  If not there can be a lot more wrong.  When was the last service?  How old are the tires?  Depending on condition the tank can be repaired and coated inside with POR 15.  Fuel pump can be purchased at a reasonable price from our sponsor Ca Cycleworks  http://ca-cycleworks.com/fp-duc  or you could get lucky and find a used tank with fuel pump.
$900 gives you a lot of leeway, but if the bike has major engine problems and needs some other major work that leeway will shrink fast.
jcolg1
Quote from: howie on May 29, 2017, 02:08:25 PM
I just contacted seller about the bike regarding if its running and about recent services. Still waiting to hear back
d3vi@nt
Belts and valves are a major service item that can cost a fair bit at the dealer. It that's something you don't want to tackle, and assuming it needs to be done, I'd recommend getting some quotes from nearby shops.
'13 MTS GT
'99 ST2
'07 M695 - Sold
jcolg1
Quote from: d3vi@nt on May 29, 2017, 05:07:02 PM
Thanks
Randimus Maximus
It'll still do 140MPH.
Trust me.
So how did you go with it?
Check eBay for the price of a replacement tank and add that to the purchase price and see what you think.
JM
