January 21, 2025, 12:14:07 PM
Please Help
Instruments and bike dead on a seldom occasion
Topic: Instruments and bike dead on a seldom occasion (Read 1634 times)
S2R 800 '07
June 07, 2017, 09:11:41 AM »
It happens only ~once a month, after my frame change and harness plug out plug back in.
Key in, turn key -> dead.
Wiggle key -> ok and stays like that for the ride
Imobilizer antenna/plug?
If it is the wires to the ignition or the ignition switch , wouldn't it stall sometimes while riding?
Re: Instruments and bike dead on a seldom occasion
June 07, 2017, 09:39:23 AM »
When it misbehaves, do the gauge needles sweep, idiot lights on, fuel pump primes, etc?
Or totally dead?
Or somewhere in between?
S2R 800 '07
June 07, 2017, 09:48:27 AM »
Can't remember for sure, but maybe partial lights and sweep OR directly to dead.
June 07, 2017, 03:43:05 PM »
If wiggling the key fixes it, I'd suspect that the ignition switch itself is giving up, or is just really dirty inside.
They can be disassembled.
And a different one can have new plates put in it to match your existing key.
I'd check both plugs associated with the ignition switch; on the switch pigtail and on the wiring harness.
Sounds like a flaky connection there, I've seen a couple cases of the individual spade/socket components losing their grip on the shell.
S2R 800 '07
June 07, 2017, 04:02:58 PM »
Wouldn't these issues cause it to stall while riding? Haven't so far... Just lucky? Or is there a safety feature keeping it running even if the connection is broken?
Quote from: Speeddog on June 07, 2017, 03:43:05 PM
Known procedure?
June 07, 2017, 04:23:01 PM »
Quote from: stopintime on June 07, 2017, 04:02:58 PM
Known procedure?
Basic locksmithing.
June 07, 2017, 05:04:28 PM »
I think you've been lucky.
Perhaps the constant wiggling of the key as the bike goes down the road is enough!
No safety feature that I'm aware of to keep it going.
S2R 800 '07
June 10, 2017, 09:29:07 AM »
Happened today - dead/black/quiet when I turned the key - wiggle a little and it's back on.
I'll check the connectors and clean the ignition switch 'soon'.
