How to unhook exhaust springs?
Started by Wzed, May 22, 2019, 07:58:26 PM
Wzed
I need to take my exhaust system apart, but I can't get the springs that hold it together to come off; should I just take a pair of needle-nose pliers and pull them apart, or is there some special technique or tool?
amcjen
There's a tool:
FMF Racing 11231 Pipe Spring Tool https://www.amazon.com/dp/B00JXOPMQG/
But I have used needle-nosed pliers and you can do it if you're careful. I'd highly recommend safety glasses tho. They are on there pretty good.
I've got one like that, it's quite good.
And yeah, glasses always.
S21FOLGORE
Go to local NAPA store and get this if you are in a hurry.
https://www.napaonline.com/en/p/SER3474
(I personally like NAPA one better than more common "T" handle type.
https://www.sportbiketrackgear.com/motion-pro-heavy-duty-spring-hook/
Wzed
Thanks guys!  I figured I must be missing something.  I always looked at those things and thought, "That's enough to hold my exhaust together?"  Turns out it definitely is.
Heath
You'll be happy when you use that tool. It's a life saver for taking them on and off.
2007 Ducati Monster S4RT
