April 27, 2024, 02:19:33 PM
new front rubber; how to break er in!?
Topic: new front rubber; how to break er in!? (Read 3025 times)
DuciD03
.... when did that happen...?
BTW: thats a bad pic of Bono, not me .... ;)
July 10, 2020, 09:26:31 PM »
little tounge-y and chee-e-ka-y!
new Pirelli on the front last weekend; (...and Im stoked!) very busy since the install and wanted to be well rested and decent weather before taking er for a rip ...
how best to break it in!? all suggestions welcome
(should I wash it in detergent and rinse? or
weave back and forth for the first 5 minutes of riding?...)
how long to get er to full grip ?
.... all the world is yours.
S2R 800 '07
Re: new front rubber; how to break er in!?
July 11, 2020, 01:51:02 AM »
You won't use full grip. After a couple of heat cycles they're ready though. I start with a good cleaning with a cloth and break cleaner.
July 11, 2020, 02:39:45 AM »
I don't do anything other than making sure the stickers are removed.
July 11, 2020, 03:12:37 AM »
My tyre guy wipes them down with shellite.
d3vi@nt
July 11, 2020, 06:55:32 AM »
What's the idea behind wiping down the rubber with chemicals?
'13 MTS GT
'99 ST2
'07 M695 - Sold
July 11, 2020, 06:58:44 AM »
The slick sh*te on the tire is mold release agent from the tire manufacture. It needs to be removed. Chemical agents as described above remove said agent. You can (if you want) leave it on and ride carefully if you like. I use the chemical agents myself.
d3vi@nt
July 11, 2020, 07:34:42 AM »
From what I've read, most moto tire manufactures quit using mold release agents over a decade ago, Pirelli being one of them.
Michelin's run-in instructions (
https://www.michelin-training.net/courses/motorcycle_tire_basics/english/ipad/index.html
) basically say take it easy and gradually increase lean angles over 60 miles.
Pirelli is basically the same:
Run In
After fitting, the tire should not be used under maximum power or excessive cornering and not over 60 MPH for the first 200 miles to adjust the tire/rim assembly. After the run in period, speeds may be increased progressively (within legal speed limits and safe operating conditions). Be sure to check the air pressures during the run in process.
I'm thinking we have the makings of an oil thread here.
'13 MTS GT
'99 ST2
'07 M695 - Sold
S21FOLGORE
July 11, 2020, 08:03:55 AM »
+1 on above post.
More than 10 years ago, all major motorcycle tire manufacturers stopped using release agent.
You can call and ask Bridgestone customer service. (Or, Pirelli, Dunlop, Michellin, ...)
"Slippery because of release agent) is the old story from 1970s and 80s.
Back then, yes, tire manufacturers used so called "release agent", which is kind of lubricant, that makes releasing the tires from the mold easier. And brand new tires had them still on the tread surface, hence they were slippery in first 50 miles or so.
So, DON'T USE BRAKE CLEANER (or parts cleaner) ON YOUR TIRES !
These harsh chemicals DO DAMAGE rubber, tires, brake caliper piston seals, etc.
July 11, 2020, 08:11:41 AM »
Quote from: d3vi@nt on July 11, 2020, 07:34:42 AM
Run In
This
DuciD03
July 11, 2020, 08:34:51 AM »
Pirelli is basically the same: Run In After fitting, the tire should not be used under maximum power or excessive cornering and not over 60 MPH for the first 200 miles .
I'm thinking we have the makings of an oil thread here. ...lol
1+
but semi-serious too; there's more than one that would be thinking endies to warm er up (maybe not on dmf) … and thought of break cleaner; detergent with a good rinse etc and … remember being out on new Pirelli rear that was sliding around on me in damp morning conditions, gearing down, with the dry clutch; … was testing its limits on the straight; very carful in corners
July 11, 2020, 04:11:51 PM »
While the mfrs dont grease the pan anymore my tyre guy wipes them down as a courtesy due to who knows what from where could be on them in the process of them arriving. Anything can get on tyres prior to and during fitting.
He has worked for Moto3 teams, has a close relationship with Pirelli and says its part of best practice to those in the know. The tyre mfrs don't want the average punter wiping tyres down with chemicals and damaging the compound. Just follow the mfrs instructions. I'm glad my tyres are wiped down and I used to do them myself.
Charlie98
Marveling at my
McKinney, TX
July 11, 2020, 06:47:51 PM »
Koko, what do you use, or what does your dealer use?
Dennis
2013 M796 ABS
DuciD03
July 11, 2020, 07:56:32 PM »
Quote from: Charlie98 on July 11, 2020, 06:47:51 PM
lol...
ya! wtf do they use?
I opted to go naked; no chemicals; no detergent; as what duc painter does … and the first dam stop light I came too changed faster than anticipated; did an overly abrupt stop …. without consequence but conditions were good; wondered if I should have done a quick wipe with brake cleaner ...
Last Edit: July 16, 2020, 07:45:26 AM by DuciD03
d3vi@nt
July 11, 2020, 08:03:25 PM »
Shellite (from previous post). Basically a form of naphtha, which is a pretty toxic solvent. Apparently not friendly to rubber.
'13 MTS GT
'99 ST2
'07 M695 - Sold
Reply #14 on:
July 11, 2020, 09:17:56 PM »
I used to use Prepsol. I have been known to chuck on some tyre warmers or lightly scuff new tyres with foam backed sand paper.
"We taking it easy today?", "Sure". Hangs up phone...
Bike on race stands with tyre warmers.
