new front rubber; how to break er in!?
Started by DuciD03, July 10, 2020, 10:26:31 PM
Charlie98
Quote from: DuciD03 on July 11, 2020, 08:56:32 PM
wondered if I should have done a quick wipe with break fluid ...
Brake fluid... or break fluid?   ;D
Dennis
2014 MTS 1200S Pikes Peak
2013 M796 ABS
Oh no imo. Just take it easy for a hundred.
A thought, too high a tyre pressure can delay or prevent warm up, depending on how you're riding. Once, just once I didn't immediately check the psi on new tyres fitted and later found them at 41 psi both ends in cold conditions. I was skating all over the place which reminded me to do so. Some tyre fitters see the "max 41 psi" on the sidewall and just fill er up.
Charlie98
I think a lot of service guys just air them up to make sure they pop the bead and seat it... and just put them on that way.  The burden is always on the rider....
Dennis
2013 M796 ABS
DuciD03
Quote from: Charlie98 on July 13, 2020, 06:38:24 AM
Brake cleaner fluid ...    ;D
-sigh- just realised my typos  :P… corrected
.... all the world is yours.
I think it's too strong a substance.
Since tyre Mfrs don't "grease the baking pan" anymore you should avoid trying chemicals to be safe. Just give em a hundred miles gradually increasing lean angle. Advice i was given was to ride new tyres in the dry like you would in the wet for the first 100.
I shared what my tyre guy still does and what I used to do. I sometimes regret sharing some of the old school practices :P
