Starter Circuit Diode Size
Started by He Man, November 12, 2020, 11:43:00 AM
I remove the wire between the starter relay and the main harness for inspection. It turns out that the wire is toast mc-ghost to the point where the copper is coated with a nice black coat of i dont know what. Im guessing this is what happens when the wire gets overloaded from the starter (hence why there is a diode there i suppose).
When i jump the relay the bike cycles like a beaut, but when i hit the starter it replicates a dead/dying battery. I suspect that the signal from ecu is getting jambled by the burnt wire and i could replace it, but i want to get the right diode and replace that as well.
Does anyone have that diode spec so I can buy one at .......online...(cause radio shack no longer exists).
I know that diodes are marked with stripes and lettering but this one is too corroded to read.
battlecry
My '03 800S manual lists the diode as a 1N4007.  Bar on the diode to the R/G, tail of the triangle to the R/Bk wire.  Hope that helps.  R
very helpful, is this listed in a parts manual somewhere?
Good to know. Thanks guys!
Hopefully this brings some life back into the starting circuit!
