Multistrada ohlins forks on s2r1k
Started by Alexaskmo, January 04, 2021, 11:22:41 PM
Alexaskmo
Sooo, just got a pair of ohlins forks from a multistrada s 1000ds for super cheap. Now I was thinking of throwing them on my s2r1k. Any thoughts, straight swap or is this going to require a bit of work? :)
/Alex
Have you measured the length?  IIRC, Multi forks are longer...
greenmonster
Yup, longer, and MTS have model specific wheels, probably different disc offset, lots to check.
M900 -97
MTS 1100s  -07
New wheel/suspension travel will be longer = bike sits higher to allow for the travel / fender & wheel hit the lower triple / suspension must be re-constructed to become shorter.
Alexaskmo
#4
Ok,
Plan b, what about as compared with the st3, would that make sense? :)
Edit: unclear, I mean would putting the multi ohlins forks on an st3, does that swap make more sense?
Best,
Alex
Quote from: Alexaskmo on January 06, 2021, 08:02:15 AM
Ok,
Best,
Alex
I think so. I have a pair from an ST4, so if ST3 and ST4 are compatible - so are ST3 and S2R.
greenmonster
Quote.Edit: unclear, I mean would putting the multi ohlins forks on an st3, does that swap make more sense?
No, same problems.
M900 -97
MTS 1100s  -07
