July 18, 2024, 01:29:56 AM
Statler
ML builds an old truck
27
28
29
30
38
Topic: ML builds an old truck (Read 48772 times)
The best kind of whore is a
Re: ML builds an old truck
Reply #405 on:
November 02, 2023, 10:44:02 AM »
But where would I get an empty bean can??
For $50 you can touch my
Reply #406 on:
November 02, 2023, 12:14:17 PM »
Quote from: Monsterlover on November 02, 2023, 10:44:02 AM
This is relevant.
Reply #407 on:
November 02, 2023, 12:19:34 PM »
Reply #408 on:
November 02, 2023, 12:32:05 PM »
Quote from: Popeye the Sailor on November 02, 2023, 12:14:17 PM
This is relevant.
Someone should invite her to DIMBY.
Reply #409 on:
November 02, 2023, 07:01:28 PM »
The turbo set up and the bean video made my eve
Reply #410 on:
November 04, 2023, 02:38:04 PM »
Switches are going here
2023-11-04_06-24-22
by
Kevin Ames
, on Flickr
Bought HID headlights. High and low beam and white DRL that toggles to amber as a turn signal.
2023-11-04_06-24-34
by
Kevin Ames
, on Flickr
2023-11-04_06-24-42
by
Kevin Ames
, on Flickr
2023-11-04_06-24-50
by
Kevin Ames
, on Flickr
2023-11-04_06-24-58
by
Kevin Ames
, on Flickr
Picked up some reproduction Mooneyes cast aluminum light mounts. It's clears the tire but not by much. I designed a 2" riser that fits under the light pod and makes plenty of clearance. I tested that by 3d printing a sample and it worked great (not actually shown in the pics).
2023-11-04_06-25-10
by
Kevin Ames
, on Flickr
No trim rings came with the truck so I designed and 3d printed a sample which worked great. I'll make these from aluminum. 3 holes actually mount the ring to the pod (sandwiching the light) the rest of the holes are just blind tapped to make it look like it has nine bolts holding it together
2023-11-04_06-25-21
by
Kevin Ames
, on Flickr
2023-11-04_06-25-28
by
Kevin Ames
, on Flickr
Switch panel template. Holes needed adjusted. My CNC plasma pal is going to burn it out of 16ga and we'll powder coat it
2023-11-04_06-25-37
by
Kevin Ames
, on Flickr
This floor. make the beast with two backs this floor 🤣 The passenger side hit me hard with lessons. Next time I'm doing the floor a little differently. But it fits and it's functional. I still need to make some patches to cover the bolts in the corners but that's for another day. I'm tired of looking at it right now so I'm working on other things
2023-11-04_06-25-45
by
Kevin Ames
, on Flickr
Ultimately I'll make a right angle patch to cover this seam that will be riveted into place.
2023-11-04_06-25-54
by
Kevin Ames
, on Flickr
2023-11-04_06-26-02
by
Kevin Ames
, on Flickr
That's it for now ...
Feral 859
Reply #411 on:
November 04, 2023, 02:45:38 PM »
Enjoying the ride
Reply #412 on:
November 05, 2023, 10:24:34 AM »
Lookiong good
Reply #413 on:
November 26, 2023, 06:19:12 PM »
Had to take s few weeks off. I lost two weeks to Covid. 0/10. No desire to ever experience this again. The past week I've been at about half power. Feeling pretty good now though. Managed to work a little last weekend and a good bit this weekend at the shop machining rings and risers.
More floor work. I decided to add curved triangular panels to fill in
2023-11-26_09-06-18
by
Kevin Ames
, on Flickr
2023-11-26_09-06-31
by
Kevin Ames
, on Flickr
2023-11-26_09-06-39
by
Kevin Ames
, on Flickr
Headlight trim/retaining rings. None came with the truck so I designed my own. 3d printed one to test and since that worked I made aluminum ones.
2023-11-26_09-06-57
by
Kevin Ames
, on Flickr
2023-11-26_09-07-05
by
Kevin Ames
, on Flickr
2023-11-26_09-07-13
by
Kevin Ames
, on Flickr
Only three holes are actually for mounting screws. Because it looked weird like that the rest of the holes are just tapped blind for some short 1/4-20 bolts to make it look more serious.
2023-11-26_09-07-21
by
Kevin Ames
, on Flickr
Cast aluminum replicas of some Mooneyes light stalks from, I'm guessing, the 60's.
2023-11-26_09-07-33
by
Kevin Ames
, on Flickr
2023-11-26_09-07-41
by
Kevin Ames
, on Flickr
2023-11-26_09-07-49
by
Kevin Ames
, on Flickr
Tapped the frame 1/4-28. It's actually pretty rigid. 12pt bolts to match everything else on the front end.
2023-11-26_09-07-57
by
Kevin Ames
, on Flickr
I love the way this came out
2023-11-26_09-08-07
by
Kevin Ames
, on Flickr
2023-11-26_09-08-14
by
Kevin Ames
, on Flickr
2023-11-26_09-08-20
by
Kevin Ames
, on Flickr
Reply #414 on:
November 26, 2023, 07:15:42 PM »
I like the effect. Old truck with cyborg headlights.
Something like what I was going for in my house using rough sawn posts to hold up engineered beams.
Reply #415 on:
November 27, 2023, 06:40:43 AM »
Rather fancy!
Reply #416 on:
November 27, 2023, 08:10:18 AM »
I love it.
Speedbag
And the Intrepid
Since 2004!
Reply #417 on:
November 29, 2023, 07:54:16 AM »
Quote from: ducpainter on November 26, 2023, 07:15:42 PM
This. Those headlight rings look killer.
Reply #418 on:
December 02, 2023, 10:13:24 AM »
Here I was thinking the passengers side headlight housing was the same as the driver's side.
It's not even close. My parts don't work
Reply #419 on:
December 03, 2023, 12:15:51 AM »
That sucks
27
28
29
30
38
