ML builds an old truck
Started by Monsterlover, March 19, 2021, 07:59:32 PM
Bonus pic because I thought it looked cool
PXL_20240218_231616117 by Kevin Ames, on Flickr
1.21GW
Quote from: 1.21GW on February 18, 2024, 05:39:52 PM
How's the eye, ML?
Still in place, providing visual input daily.
I think that incident changed my prescription though. Or maybe I've just stepped up to the next level of "old"
Kopfjager
Been busy building under cab paneling and a brake/clutch/throttle pedal bracket to bolt to the firewall. Finished up the final welds on that today.
PXL_20240225_214728383 by Kevin Ames, on Flickr
PXL_20240225_214836591 by Kevin Ames, on Flickr
PXL_20240302_191233312 by Kevin Ames, on Flickr
PXL_20240302_191238568.MP by Kevin Ames, on Flickr
PXL_20240302_221959309 by Kevin Ames, on Flickr
PXL_20240302_221953053 by Kevin Ames, on Flickr
PXL_20240302_221949159.MP by Kevin Ames, on Flickr
PXL_20240302_193313726 by Kevin Ames, on Flickr
PXL_20240302_193654292 by Kevin Ames, on Flickr
PXL_20240302_193636584 by Kevin Ames, on Flickr
PXL_20240302_193659097.MP by Kevin Ames, on Flickr
So the masters are in the cab as opposed to the engine compartment?
Quote from: ducpainter on March 03, 2024, 05:35:41 AM
Correct. Reservoirs are remote mount on the fire wall- engine side
Are you going to run one, or two reservoirs?
Three. Clutch gets its own and the brake pedal gets a reservoir for each master.
Quote from: Monsterlover on March 03, 2024, 11:46:00 AM
Que?
Two brake masters? Do tell.
Quote from: ducpainter on March 03, 2024, 11:51:43 AM
Que?
Check the picture of the pedal assembly in the truck again. There are three masters there. The clutch gets its own, the front brakes gets their own reservoir and master and the rear brakes get their own reservoir and master.
There is a balance adjustment in the pedal assembly to fine tune front rear ratio.
It's a safety thing. If one of the systems fails you still have either front or rear brakes. Or you've lost them both and you're totally hosed 🤣
Dual mastes are also a requirement for a PA Street Rod registration since I abandoned the antique registration idea.
Odd that a street rod needs two brake masters and every other 4 wheeled vehicle on the road only needs one. Granted they're split systems with a proportioning valve..  ???
Carry on.
Quote from: ducpainter on March 03, 2024, 12:18:44 PM
Carry on.
Split master is required for vehicles running tires wider than 9 in. If I were running skinnier tires then I could just go with a single master and a proportioning valve somewhere.
Still seems odd, to me anyway. WTF does tire width have to do with it? [laugh]
Quote from: ducpainter on March 03, 2024, 12:45:50 PM
God knows. I don't make the rules I just dance around them ;D
