ML builds an old truck
Started by Monsterlover, March 19, 2021, 07:59:32 PM
Quote from: Popeye the Sailor on March 05, 2024, 06:09:14 AM
Do you neutralize the Rust-Mort in some way after or just prime right over it?
Keep it wet until the rust is gone/converted, then rinse.
Rust mort requires a water rinse to stop the reaction then dry it so flash rust doesn't start. Needs primed pretty quick after.
Or so the data sheet says
Quote from: ducpainter on March 05, 2024, 07:42:09 AM
No auto body supply house nearby?
There's one in the next town but I dislike the asshole running it.
My normal distributor is in Worcester, somehow their prices are close to those at coast airbrush-I normally go there but didn't feel like driving-I've got a bunch of welding and what not before I need it, anyway.
I haven't figured out how I'll rinse it yet.
The cab will be suspended in the air by my motor crane and I'll be laying underneath it working overhead.
I don't have any water in that building either.
Quote from: Monsterlover on March 05, 2024, 08:41:25 AM
Get a cheap garden sprayer. Pump it up and git er done.
It's important to remove all the rust-mort. Primer won't stick to the residue.
Quote from: Monsterlover on March 07, 2024, 01:56:04 PM
How does this stuff rate?  It's my plan b in case I can't get Rust Mort.
https://warehouse9000.com/products/3-aerosol-cans-rust-converter-stops-corrosion-rust-paintable-usa-made_112974542420_
This is how it turns into a "What'd you make the beast with two backs up now" call  ;)
Plan c is wire it to bare metal and prime.
I don't want to have to get down to plan c
Reporting in.
I have the cab hanging and used a wire brush to scrub the underside of the cab. The rust wasn't very thick.
So far I've brushed on two coats of rust mort. It takes a long time to dry between coats. 45 minutes  or so. The temp is 65°+
It's not turning black at all. Either something is wrong or it takes a while to blacken. The sheet says leave it cure for 24hrs then wipe down with a wet rag.
Quote from: ducpainter on March 10, 2024, 01:19:37 PM
Is anything happening?
How would I know?  I'm still waiting for the second coat to dry. It's been about 40 min. Looks the same now as when I started. Except it's wet.
I never let it dry....always kept it wet the whole time..
Killing cancer is a tough proposition, and never quick.
