April 27, 2024, 04:31:03 PM
Statler
ML builds an old truck
6
7
8
9
37
Topic: ML builds an old truck (Read 41967 times)
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Re: ML builds an old truck
Reply #90 on:
December 19, 2021, 11:30:18 AM »
Quote from: Monsterlover on September 29, 2021, 10:15:53 AM
I'm having three pedal thoughts now ...
Yeah... nah
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
The best kind of whore is a
Reply #91 on:
December 19, 2021, 12:09:06 PM »
Quote from: ungeheuer on December 19, 2021, 11:30:18 AM
Yeah... nah
Really? You're against manual transmissions?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #92 on:
December 19, 2021, 12:49:54 PM »
Quote from: Monsterlover on December 19, 2021, 12:09:06 PM
Nope.. Only one auto trans on our fleet. But for this application I'd want auto.... but that's me.
And this is your build
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Reply #93 on:
December 19, 2021, 02:19:29 PM »
Quote from: ungeheuer on December 19, 2021, 12:49:54 PM
I have to rip gears. It's in my blood.
Feral 859
Reply #94 on:
December 19, 2021, 03:22:43 PM »
It’s gotta have 3 pedals.
“Woohoohoohoo! Two personal records! For breath holding and number of sharks shot in the frickin\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\' face!“
Speedbag
And the Intrepid
Since 2004!
Reply #95 on:
December 20, 2021, 06:22:35 AM »
Quote from: Monsterlover on December 19, 2021, 11:02:48 AM
I'm also grabbing a crate rear end. Looking like a 9" with a Detroit Tru-trac diff. 4:11 gears with the T56 trans should put me at 80mph around 2000 rpm in 6th gear. I can make that work. The 9" should hold all the power I can throw at it.
Proabably U joints would be the weak link.
1350 u-joints will take everything you'll throw at them. The aftermarket makes some very stout units, spec a 1350 yoke when you order up the axle.
Reply #96 on:
December 20, 2021, 06:59:52 AM »
Quote from: Speedbag on December 20, 2021, 06:22:35 AM
Good advice, thanks!
Reply #97 on:
December 31, 2021, 09:47:33 AM »
Getting ready to cut 5-1/2 inches out of this frame so I can put a short bed on a long bed frame.
2021-12-31_12-43-14
by
Kevin Ames
, on Flickr
Reply #98 on:
December 31, 2021, 11:04:00 AM »
Just about ready to cut it
2021-12-31_01-56-57
by
Kevin Ames
, on Flickr
Randimus Maximus
'01 996SPS
Reply #99 on:
December 31, 2021, 11:19:43 AM »
Quote from: Monsterlover on December 31, 2021, 11:04:00 AM
2021-12-31_01-56-57
by
Kevin Ames
, on Flickr
I hope you have measured at least twice.
you may be a god
Reply #100 on:
December 31, 2021, 11:46:13 AM »
Quote from: Randimus Maximus on December 31, 2021, 11:19:43 AM
Kind of one and a half times. I'm pretty sure I got it right. And, since nothing I do yet really makes a difference in the long run this isn't that big of a deal. If the mounting holes are off for the bed I'll just redrill them.
The entire rear suspension is going away anyway so I don't even have to keep things square for that although I will obviously.
Reply #101 on:
December 31, 2021, 12:16:23 PM »
2021-12-31_03-14-42
by
Kevin Ames
, on Flickr
Reply #102 on:
December 31, 2021, 01:00:29 PM »
Some pie cuts to allow me to adjust the angle of the frame since the front part of the frame is narrower.
2021-12-31_03-59-35
by
Kevin Ames
, on Flickr
Reply #103 on:
December 31, 2021, 01:25:18 PM »
What are you using for a weldor?
Reply #104 on:
December 31, 2021, 01:37:40 PM »
Quote from: ducpainter on December 31, 2021, 01:25:18 PM
I'm going to tack it together with a Miller synchro Wave 180 TIG. Final welding will be a 250 amp Lincoln MIG welder I picked up at an auction. I'm also going to plate the outside and fit a 6x2 channel on the inside of the frame rails as far as I can go in each direction over the seam.
I'm also going to box the frame and I'll tie that into the 6x2 channel.
I'm not a fabrication scientist for a living but I think that might be enough.
6
7
8
9
37
