April 27, 2024, 06:53:10 AM
Statler
ML builds an old truck
5
6
7
8
37
Topic: ML builds an old truck (Read 41938 times)
For $50 you can touch my
Re: ML builds an old truck
Reply #75 on:
August 26, 2021, 12:35:32 PM »
Quote from: Monsterlover on August 26, 2021, 09:42:30 AM
I did some reading and read 45 or so.
Honestly half of my resistance is that it's an AOD lol. I suppose I could look at a 700R4 which I think is a TH400 upgraded to an overdrive unit.
I'm not sure I would need overdrive anyway. I can tell you this thing is not going to spend much time on the highway.
It's a long trek to dimby.
Reply #76 on:
August 26, 2021, 12:54:06 PM »
It’s an International. What could be more “international” than mating different driveline components?
Also, who cares! Run what’s best. Also, imagine the looks when that rig goes blasting past pedestrian automobiles at 90mph on the interstate…
triangleforge
I'm just a guy. I'm no
2000 Cagiva Gran Canyon
Reply #77 on:
September 05, 2021, 11:19:51 AM »
Don't know if you've got power steering figured out, but I came across this interesting solution to project car PS:
https://www.thedrive.com/news/41845/toyota-prius-power-steering-works-in-almost-any-project-car
The best kind of whore is a
Reply #78 on:
September 05, 2021, 12:29:15 PM »
Quote from: triangleforge on September 05, 2021, 11:19:51 AM
That is absolutely genius. I'll definitely look into that. Thanks for sharing!
Reply #79 on:
September 05, 2021, 06:29:34 PM »
Quote from: Monsterlover on September 05, 2021, 12:29:15 PM
I can't recall, but some of electric power steering units need a control box. Pretty sure the Saturn Vue box, the Equinox and a few others. There is an aftermarket control kit to make them work, and they have a knob so you can tell the box what level of assistance you want.
This guy does 'em.
https://epowersteering.com/purchase/product/basic-eps-controller-saturn-vue-chevy-equinox-units
I'm pretty sure I have one of those boxes, but I need to find it to see which one. You can have it, of course. Assuming it'll fit.
I'll try to dig it out in case you go electric.
Reply #80 on:
September 05, 2021, 06:40:44 PM »
Quote from: Davey Two Tractors on September 05, 2021, 06:29:34 PM
This guy does 'em.
Nice. If I can fit an electric assist I will. There's so many unknowns at the moment.
At this point I think I will test fit/tack in place the entire truck to make sure it will all work.
Randimus Maximus
'01 996SPS
Reply #81 on:
September 05, 2021, 07:37:06 PM »
Basically, the benefit of using the Prius unit is that if hooked up to straight 12V, it operates in "limp mode", which means it provides assist assuming the vehicle is at 43MPH.
I might know a guy that can get you a new unit at cost +10%.
But I'm sure there are plenty out there from a salvage standpoint (we sell very few of those units, even though most of our vehicles have utilized that set up for the last 10-15 years).
you may be a god
Reply #82 on:
September 06, 2021, 03:45:45 AM »
Quote from: Randimus Maximus on September 05, 2021, 07:37:06 PM
I will keep this in mind
Looks like they're around $150 used. I couldn't find a cost on a new one.
ZLTFUL
WWSDD? Why Anal of course!
Reply #83 on:
September 18, 2021, 01:33:35 PM »
I would stick with the TH400 unless you go PowerGlide which is even more bulletproof. And if OD is ever a concern, then pick up a Gear Vendors OD unit. Built for up to 2000hp, replaces the 4" tall housing, direct bolt on and simple push button actuation/disable.
https://www.gearvendors.com/product/automatic-3-speed-t-400-mech-speedo-11/?TYPE=STREET-STRIP&FUEL_TYPE=GAS
Granted, that's a $3k investment. But we are only here to help (spend your money).
Avatar courtesy of
www.mybadco.com
2012 Panigale 1199
2003 KTM 640 Adventure
Reply #84 on:
September 18, 2021, 02:33:58 PM »
Quote from: ZLTFUL on September 18, 2021, 01:33:35 PM
Yeah that's a nice unit but that cost
Reply #85 on:
September 29, 2021, 10:15:53 AM »
I'm having three pedal thoughts now ...
triangleforge
Reply #86 on:
September 29, 2021, 11:46:35 AM »
Do it!
I need to get manual transmission back in my life. Four wheeled, that is.
Reply #87 on:
September 29, 2021, 11:51:06 AM »
Quote from: triangleforge on September 29, 2021, 11:46:35 AM
Do it!
I have a six-speed in my 2017 Mustang and I like it. For performance vehicles I really feel like a manual is the choice that's best. There's nothing like ripping gears while standing on the throttle.
Sadly, also works as an anti-theft device.
Reply #88 on:
December 19, 2021, 11:02:48 AM »
Well, the manual trans is all but a done deal. I'm ordering a Tremec T56 6spd and all the parts that go along with it (flywheel, double disc clutch etc) next week. I may have to add a transmission tunnel to the cab but I'm willing to do it.
I'm also grabbing a crate rear end. Looking like a 9" with a Detroit Tru-trac diff. 4:11 gears with the T56 trans should put me at 80mph around 2000 rpm in 6th gear. I can make that work. The 9" should hold all the power I can throw at it. Proabably U joints would be the weak link.
Tremec warranties the T56 to 700 foot pounds of torque
Since I have a long bed frame and a short bed to go on it I'll have to section the frame something like 8-12 inches. After that I can set the rear end, wheels and tires approx where they'll live. I found a local guy that builds hot rod frames or whatever you want and he's going to stop down, take measurements and build some control arms for me.
I'm going to run the Mustang 2 front end that's in there now and see how it goes. We'll build longer control arms to fit that allow a wider track width. I'm shooting for something in the 75" range.
More to come...
Feral 859
Reply #89 on:
December 19, 2021, 11:18:51 AM »
Oh hell yeaah!
“Woohoohoohoo! Two personal records! For breath holding and number of sharks shot in the frickin\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\' face!“
5
6
7
8
37
