Marks (now solo) M1100 (mis) adventures!
Started by Mhanis, December 02, 2022, 01:51:04 PM
Charlie98
That shock bolt would have come out by itself... if you were drinking Peroni.   [shot]
Dennis
2013 M796 ABS
Mhanis
Quote from: koko64 on January 29, 2023, 12:15:23 AM
That recessed section around the bolt should hold some anti seize liquid. Worth filling it with the swingarm on its side overnight. Nothing to lose. An impact driver should work and will damage the Allen head so you would replace the bolt, but a rattle gun will chew it out much worse.
This was the winner, thanks for the advice. All set with that bolt.
It has gotten COLD here again, so no progress to be made the early part of this week.
Mark
Pete Townshend
Mhanis
Cripes, another day, another bolt problem. At least this one is little, literally:
20230204_153220 by Mark Hanis, on Flickr
20230204_162146 by Mark Hanis, on Flickr
This little bastard decided to break. I know there are options for using reverse threaded tools but I am afraid there is not enough meat here support something like that. There is enough exposed that I can get plyers/channel locks on the end, but I get to movement. I am working Koko's PO Baster and set up method, but is there something specific tool wise I should be using for such a small bolt?
[roll] ???
Mark
Pete Townshend
A mole wrench could be a vice grip or a locking adjustable wrench.  This is a Channel Lock, actually a brand name   https://channellock.com/product/430/
What I would do is grind or file that broken screw flat, center punch as close to center as possible and drill with a left hand bit while praying to whatever deities you can think of.
Quote from: Howie on February 04, 2023, 06:38:05 PM
Ah, multigrips  :)
Mhanis
Mole wrench, Multigrips....WTF!?
You cannot be MAKING names up for tools!  ;D
So Howie, there are bits that that that small that are reverse thread?
Mark
Pete Townshend
Size of the screw?  I will look at my set tomorrow if I remember.
Yeah, koko64.  A muliigrip that doesn't bust your knuckles.
Quote from: Mhanis on February 04, 2023, 08:56:26 PM
Mark
Where I come from a wrench is a spanner and we don't root for our teams ;) Grab that mothermake the beast with two backser with some multigrips after soaking in penetrine.
Mhanis
Quote from: koko64 on February 05, 2023, 02:44:27 AM
That's because all of the blood is flooding your brain from standing upside down all day.  [laugh]
Howie, the part number I have is 772.1.085.1C if that helps.
Mark
Pete Townshend
Do try what koko suggests first but with vice grips first.  Channel locks will not bite well enough and only chew up more of what is left.  I'll look up the part number shortly.
As far as I know, the smallest drill bit you will probably find is 1/16" you would have less than .003", in my opinion too close.  If vice grips fail, maybe https://shop.snapon.com/product/Extractor-Set/Screw-Remover-Set-(Blue-Point)/YA2019
Quote from: Howie on February 05, 2023, 07:26:32 AM
Howies right, use a Mole Wrench set very tight. The painted surface rules out heat. It's tricky.
Mhanis
#74
Thanks for the advice on that little bastard. I'll keep you posted.
Next problem; I am working on the whole throttle body assembly and I cannot figure out what to with these connections:
Got it figured out!
20230205_124945 by Mark Hanis, on Flickr
20230205_125003 by Mark Hanis, on Flickr
I just don't get how there are disconnected.  ???
Oh, and this too:
20230205_130551 by Mark Hanis, on Flickr
Easy enough to replace once I get the throttle bodies pulled?
Mark
Pete Townshend
