Marks (now solo) M1100 (mis) adventures!
Started by Mhanis, December 02, 2022, 01:51:04 PM
I'm gonna say about 150+. A bit more with whatever stand you use.
Mhanis
My new engine is on a small pallet and just going by the "it feels about" method I'd say DP is in the ballpark.
I didn't think about it until now, but I'll check the shipping documents and see if there is a weight on there.
Mark
Pete Townshend
Quote from: ducpainter on December 11, 2022, 10:46:00 AM
About 70kg I reckon ;D
Mhanis
Howdy boys and a Happy New Year!
Not much going on here the last few weeks but I did do a bit tonight. I pulled the chain off as it needs replacing and I figured I'd drain the oil as well. When I pulled the magnetic drain plug, I found this:
20221229_181649 by Mark Hanis, on Flickr
Is that consistent with what you'd expect based on the diagnosis? As a refresher based on the output shaft movement I was told that it needed to be reshimmed (paraphrasing). I am just curious because I was kinda shocked when I saw the shavings on the drain plug.
Additionally, I pulled the Rizoma belt covers off and found this:
20221229_181710 by Mark Hanis, on Flickr
Which means my vertical cylinder rear belt tensioner was rubbing against the cover. Normal?
Again, it isn't really that important and I have a new motor; I am just wondering what the collective thought is.
I'm going to bring the engine to the dealer for desmo service one day next week, I should have a ballpark weight on the engine alone once we get to moving it.
Cheers boys, shit is happening!
Mark
Pete Townshend
Charlie98
Dennis
2013 M796 ABS
That's a fair amount of metal shards on the magnet rather than the usual metallic sludge.
Mhanis
I did not cut the filter open, but it is still in the drain pan. Watcha thinking?
And of course I was going to get the engine to the dealership tomorrow for the once over and a coil on my truck decided to take a shit! Easy enough job, expect it is still missing after replacing said coil.  [bang] [thumbsdown]
Eff me......
Mark
Pete Townshend
Charlie98
coil over plug?
Are you sure of the cylinder that's not firing?
Dennis
2013 M796 ABS
Mhanis
Quote from: Charlie98 on January 03, 2023, 05:31:56 PM
coil over plug?
Yep, coil over plug. I was told #1 and that #1 is the front passenger side. I confirmed that is where #1 is. I assume the dude at Autozone knows how to read the information that the error code reader spits out......
Mark
Pete Townshend
Mhanis
It turns out the truck had an injector failure, not a coil failure.
Fixed this weekend and I'll be able to get the engine moved next week.
Fingers crossed...........
Mark
Pete Townshend
Mhanis
I finally got the engine to the dealership and the bike is getting torn apart.
I have everything removed to take the swingarm off except the shock: is the best option removing the shock from the bike (at the top) or remove the shock from the swingarm (at the bottom)?
My rolling workbench is working like a charm, I am glad I did that!
Mark
Pete Townshend
Whichever way let's you remove the top bolt head without scratching the frame with the tool. The lower bolt is accessed via lifting the swingarm on a rear stand while the motor is on an engine stand. Others may have some  different tricks.
Not happening.  Maybe next winter.  I can't raise the required enthusiasm....
Mhanis
Motivation is a weird thing. I absolutely LOVE to go shooting, it is just that most of the time I don't WANT to!
The excitement of me replacing the engine has been replaced by the fact that I now MUST replace my engine!
I will still post things that I think may be helpful to you Ung.
The engine is still at the dealership; the mechanic said the valves were out of whack pretty good, so good thing that was my first stop!
I should have it back this week then I can go DEEP into my plan.
Mark
Pete Townshend
Charlie98
Quote from: Mhanis on January 23, 2023, 03:29:24 PM
Mark
That was me this past Sunday.  I hate going to public ranges on the weekend... but I did because my daughter's boyfriend wanted to go, and Sunday is the only day he has available.  I joined that Texas Legends place in Allen... which seems decent enough.
Question:  Referencing the 2V air cooled motors in general... the standard service interval is 7500mi, do the valves really go out of tolerance that much in 7500mi?
Dennis
2013 M796 ABS
