Open Clutch Cover Advice
Started by roy-nexus-6, August 12, 2008, 02:17:57 AM
roy-nexus-6
Getting rid of the stock Ducati clutch cover. I need to buy the following parts, yes?
6 x weather proof springs.
6 x  weatherproof clutch spring retainers OR 1 x clutch hub brace.
6 x weatherproof alan bolts (which I think I could get from a hardware store).
Am I missing anything here? Any sage words of advice before I take the plunge?
I haven't taken my clutch apart yet - can't seem to get home before 10pm during the week,.. keen to order some parts!  [thumbsup]
loony888
speedymoto offer a small kit that has the stainless steel springs and anodized alloy retainers, the bolts you can re use or you can buy stainless steel from the hardware, either way, use coppaslip on the threads and tighten just enough to seat them, it's VERY easy to overtighten the bolts and shear them off.
you can buy speedymoto direct or from an agent like www.cacycleworks.com
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
DosVerde
Hi Roy,
If you want to do it on the cheap or in stages, you can just put on an open cover, the springs will be fine but will rust after a while. I got a set of stainless steel springs, coloured retainers, S/S cap head bolts and a throw out bearing in a kit from Road Rocket here in Melbourne for $85. (They had it stock at the time but the guy didn't know the price so I could'nt take them, strange to deal with sometimes.) You'll probably do a bit better importing them though.
I'm still using the stock pressure plate that I cleaned up with a bit of Autosol, but would probably look blinger with a nice anodised item.
Its a piece of piss to change them over, the trickiest bit I found was punching out the old bearing from the pressure plate. Because I used the original plate i put in on exactly the same position I took it off in. If your replacing that, I believe there are some arrows or something to line up, probably makes more sense if you have it in front of you.
But apart from that, yep thats all you need, order, fit and enjoy  [moto]
DosVerde
Quote from: loony888 on August 12, 2008, 02:38:42 AM
...use coppaslip on the threads and tighten just enough to seat them, it's VERY easy to overtighten the bolts and shear them off....
Hey Paul,
I have read the same thing before I changed mine over, however, when I put the bolts on mine, they spun easily and then noticably came to a firm stop. I just left left them at that point. Does that sound right?
I thought maybe the bolts in the kit come with the correct length shoulder (unthreaded bit) as opposed to ones you buy at a hardware store.
loony888
Quote from: DosVerde on August 12, 2008, 02:49:44 AM
Hey Paul,
yep, that sounds about right, the coppaslip is there mainly to ensure water doesn't corrode the threads, as it's open and gets a lot of water and clutch dust etc it's just cheap insurance against them shearing going in or coming out.
as far as the pressure plate lining up goes, there is a slot on one of the clutch hub posts and on one of the 6 holes in the pressure plate there's either an arrow or a dot that lines up with the slotted post, easy as that.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Spider
Roy,
if needed I can add these to my Monsterparts box (leaving end of this week)
http://www.monsterparts.com/pc/06-0225/Clutch-Brakes/06-0225.html
Spider
tricolore
It really is as easy as that, It was the first thing I changed on my bike so I too was a little apprehensive but it is simple. You could just paint your stock plate and caps. I wouls however recommend replacing the bolts and springs with Staino stuff.
Have fun  [moto]
'08 S4RS Tri, '02 VOR En450, MV Agusta F4 Tracky, Ducati 900 Darmah.
roy-nexus-6
Hi all,
thanks for all of the replies!  [thumbsup]
I'm going for a very 'low-key' look - so I'll be sticking with the stock pressure plate. I've fired off a PM to Spider - all things going well, I'll be able to piggyback on his monsterparts order.  [thumbsup]
I actually did a bit of shopping today - one outfit on ebay wanted $85 US for springs, about $70 for titanium bolts - $25 postage. :o Ek, no thanks!
As for the change over, it should be pretty simple: the pressure plate won't be coming off at all as I'll be doing one spring at a time.  [thumbsup]
Thanks again, all. I'll snap a photo when I'm done (which will no doubt annoy Tool) :D
Spider
annoying the tool is what we do!
consider it done.
Good little mod and my experience was exactly like Dos's (which is good - cause I told him that it would work like that!) they seem to just thread very easily in (I put telfon grease on mine) and then STOP...I was worried about the others warnings of snappage (French term meaning to f%ck it right up!) but it felt like the bolt just hit the bottom of a well and that was it.
Dockstrada
#9
Quote from: Spider on August 12, 2008, 05:15:38 PM
consider it done.
Yeh your right spider that’s what we like to do annoy the Tool, Which reminds me ???
Hey Tool you c#*t, I just bought something and it was fu#*ing expensive :-* why don’t you try and guess so it can stoke my ego. [popcorn]
If I wasn't who i was, I wouldn't be who I am !
loony888
Quote from: roy-nexus-6 on August 12, 2008, 08:16:00 AM
Hi all,
i'll bet the std pressure plate lasts about a month!!! nice anodised ones look awesome and they don't have to be bright and gaudy, most look nice behind a cover [thumbsup]
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
goldFiSh
Quote from: Dockstrada on August 12, 2008, 05:30:28 PM
Hey Tool you c#*t, I just bought something and it was fu#*ing expensive :-* why don't you try and guess so it can stoke my ego. [popcorn]
<ski trip inside joke>
Hey Vince, his real name might be wazza.
how does it feel when your mates dont rate ya wazza?
ya dog wazza, man up ya f%3ken dog c%$t
</ski trip inside joke>
;D
sorry people back to your regular programming....
roy-nexus-6
Quote from: loony888 on August 12, 2008, 11:51:10 PM
paul.
I'll take that bet. I'll bet you a new anodized pressure plate that I keep the std pressure plate for at least one day more than a month :D
Spider
what clutch cover are you putting on?
Dockstrada
Quote from: goldFiSh on August 13, 2008, 04:49:24 AM
;D
Dog C#*t i never back down on mi mates  [laugh]
