What's up with the water that requires bottled water for drinking?
JM
Quote from: the_Journeyman on May 01, 2009, 07:03:27 AM
JM
It makes it portable...
We have a well and the water is full of scale and particles. We have a water softener that came with our house but it keeps breaking (because the water is too dirty) and the warranty didn't transfer over.  When the softener works the water is fine for washing but not great for drinking.  I think the multi-stage filter will be a much better solution. [thumbsup]
I see.  I had sulfur in the well water at one place I lived.  If you could get past the smell, it didn't hurt you, but actually helped your immune system some of the old folks said ~
JM
Quote from: somegirl on May 01, 2009, 07:13:27 AM
You guys should move to wherever the water comes out of the ground and is fit to drink. ;D
Quote from: ducpainter on May 01, 2009, 07:17:00 AM
We did have the water tested before we moved in and it is technically ok but we didn't try drinking it ourselves. :-X
Quote from: DDDDan on May 01, 2009, 03:49:37 AM
I've got the forks apart looking for the mystery clunk.  DucVet's indulging me, and hopefully keeping me out of trouble.
Had a clunk in my front forks recently too.  Turns out it was the factory dual-rate springs.  Under compression the softer rate would coil-bind before going into the harder rate.  Annoying!  I had the springs replace w/0.80 rate Race-Tech springs and the problem went away!!!
Oh yeah, it's friday more 'Ning BABY!!!  [thumbsup]
Fresh Pants
Bwooooooahhh
Braaaaaaaappp
I guess there is a little more ning left.  [coffee]
It's cloudy and not warm.
There is lots more ning left.   [coffee]  on my first couple of sips......
I was up to 2 am and up at 0830.  Work at 1230.
Have a great friday all!
Quote from: Little Monkey Toes on May 01, 2009, 09:09:52 AM
You too LMT!  Oh, and I'm out of  [coffee] now...  -sigh-  Guess I'll wait for a bit and then have some caffienated soda.
I've graduated from coffee to water, and now eating some heavily frosted cake.  Bring on sugar rush!
JM
Ddan
Quote from: Duck-Stew on May 01, 2009, 08:19:15 AM
This was clunking on both compression and rebound. I also had pretty much zero rebound damping.  I've got maybe 5K miles on the new Race Tech springs and gold valves, so I was a bit curious about what was going on in there.  So far, everything seems OK, nothing broken or loose.  I'm going to finish checking everything out, maybe send some pics to Ducvet  for a professional opinion, then fresh fluid and hope for the best.
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: DDDDan on May 01, 2009, 09:55:38 AM
Oh.  nevermind then.  [roll]
