Started by ducatiz, June 09, 2009, 12:56:37 PM
DrDesmo
Quote from: ducatiz on November 22, 2010, 12:42:00 PM
I don't think they did any harm.  If anything, it shows a costly attempt to keep bikes in running shape while they seek a solution.
I believe the problem in finding a replacement is two fold:  1, alternative materials are not as easy to homologate and/or paint to the same quality as the original and 2, the original material would be just fine if they could use some sort of barrier coating for the inner layer which would not prevent the original tank from being homologated.
The main materials used for gas tanks are layered HDPE and PEX.
HDPE is not finishable to the same quality.
PEX is more problematic to finish.
I don't know of any other materials being used in gas tanks besides PA6.
To play devil's advocate for a minute, why hasn't my 10+ year old Falco tank (Plastic, awesome finish) and/or my Sprint ST's tank had any adhesion / expansion issues?  Both plastic, both ethanol fuel, etc.  More genuine curiosity than anything... Keep up the good fight  [thumbsup]
Cheers,
Adam
'95 916
'12 800XC
herm
i imagine another issue is getting a new material tank certified as OEM (or equivalent) for the purposes of EPA/NTSB/...not to mention California compliance.
This map is upside down, the plan is written in crayon, and the weather forecast is from 2011.
arai_speed
While reading my latest copy of RRW - they have a small column on new 2011 models - two of them being the 1198 and the 1198SP - aside from the difference in suspension between the base and SP model.  The SP model also gets a larger tank (4.75-gallon vs. 4.1-gallon) and...drumroll please....an ALUMINUM fuel tank as opposed to a "composite tank" found on the base model.
So if you don't want any tank expansion problems on your next Duc - just fork out the cash for the $22K MSRP on the SP model and you'll be set!
NorDog
Couldn't they just design some drop in fuel cells?  It could cure the problem and have the benefit of an added safety factor.
DrDesmo
Quote from: arai_speed on November 22, 2010, 01:34:18 PM
IIRC, the aluminum tanks on the SP models are so they can homologate them for competition, correct?
Adam
'95 916
'12 800XC
Quote from: DrDesmosedici on November 22, 2010, 01:08:09 PM
Cheers,
Adam
I don't know, what are they made of?
My guess is that those might be blown HDPE with some kind of external hand-applied coating.  I know the Cagiva Elefants had this kind.  It was a huge pain in the ass to finish, but they were very lightweight.
Alternatively, maybe they coated them.  Bear in mind emissions regulations have changed DRASTICALLY in 10 years...
NorDog
Mhanis
Pete Townshend
muskrat
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
booger
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
arai_speed
Quote from: bergdoerfer on November 22, 2010, 09:58:01 PM
so's an OEM plastic tank
But the OEM tank comes painted - this thing you have to pay $90 to have it shipped + you gotta pay for the paint and/or painter!
Triple J
Quote from: humorless dp on November 22, 2010, 04:50:58 PM
Maybe with an old style pump and an added external pressure regulator.
They make an injected and a carbed model...there's more??  ???
NorDog
Quote from: arai_speed on November 23, 2010, 09:41:35 AM
I can't defend the shipping costs, but a couple of cans of VHT Matte Black paint is pretty cheap.
