April 28, 2024, 08:26:26 AM
51
52
53
54
191
Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates (Read 678318 times)
Re: Plastic Tank problems: Sign up list and discussion.
Reply #765 on:
August 11, 2010, 02:37:44 PM »
Quote from: Grifo on August 11, 2010, 02:36:22 PM
Just made my second claim
I wish I had the dough to but the aluminun one and get it over with
Yea, I'm on my third tank now, and noticed that it had already started to pimple a few days ago... Tank number four coming to a theater near you...
Desert Dust
Ten Most Popular Uses for a
Reply #766 on:
August 14, 2010, 02:44:24 PM »
I just received word from my dealer that my tank (07 S2R 1K) would be replaced due to expansion. Will the problem be resolved?
DucNaked
Reply #767 on:
August 15, 2010, 08:56:27 AM »
I'd say not really. You'll get a new tank, but it will be the same as the old one.
Artful
I'm glad they make pills for my
Reply #768 on:
August 16, 2010, 04:07:30 AM »
I'm in the club now too. The local dealer has been awesome so far, knew the issue, took the photos and already ordered the new tank. Looking into coating options as I type...
Reply #769 on:
August 16, 2010, 01:58:48 PM »
aha! Got an email out of no where from Nick at Rockwell Cycles, I was starting to loose my faith in them, but they came through!
New tank is en route!!! Nick was kind enough to submit me for a red one. So no more black and gold for me. and no more pirate skulls.
Not sure when it will come in, but regardless of that fact, i will pick it up after my track day and remove it for coating with the caswell stuff immediately. Is there any report on the caswell stuff? does it work? No more having to break out 90 different tools just to get my tank off. however i will miss the expanded tanks capacity, i was getting over 3.5 gallons of fuel if i ran the light +15 or so miles.
Reply #770 on:
August 16, 2010, 02:09:04 PM »
Caswell is a go. I am trying to get them to certify it will stick to our nylon tanks.
Uncle Mofo
"Must Win Track Day" Uncle Mofo Racing 2007 S4RS
Reply #771 on:
August 16, 2010, 04:55:49 PM »
Quote from: ducatiz on August 16, 2010, 02:09:04 PM
Cool! I have a new tank coming too.
2007 red S4Rs
Reply #772 on:
August 21, 2010, 12:24:34 PM »
Looks like the new Aprilias are having this same problem as well...
http://www.apriliaforum.com/forums/showthread.php?t=211397
csp808
Reply #773 on:
August 25, 2010, 11:46:44 AM »
Just applied my coating yesterday its cured today. Its a pretty stout compound i poured a test section on a dirty shop table and after 24 hours set time had to razor blade it off. Once off i i noticed it has a degree of flexibility to it seems it would hold up to a crash. The application instructions were pretty spot on but i had to clean my tank several times to get it all the way clean. I used acetone the 1st cleaning but used brake parts cleaner the subsequent cleanings to reduce the chance of damage to the paint and the tank. I'm not recommending anyone use brake clean it may have side effects depending on the chemicals your brand contains may cause adhesion issues or plastic parts to become brittle. I had to repeat the cleaning due to an oil like substance i would find traces of in the tank. Gasoline reside possibly but it had no odor. Following a dish soap cleaning and a 12 hour drying period aided with compressed air I applied the caswells coating its very honey like in appearance and texture. Take your time and roll the tank around slowly i had about 15 to 20 min working time i spent 20 minutes emptying the mixture out as it begins to get very thick. Over all not a fun thing to do but im feeling better having done it and well see how it holds up
Last Edit: August 25, 2010, 12:07:50 PM by csp808
Reply #774 on:
August 25, 2010, 12:01:45 PM »
I believe there are instructions for thinning the Caswell's product. MEK is what they recommend, but double check with them.
csp808
Reply #775 on:
August 25, 2010, 12:06:26 PM »
They did have some alternate ways to thin the compound for increasing the working time and splitting between two tanks. I wanted to keep it simple to minimize my clumsiness from screwing up the compound
arai_speed
Reply #776 on:
August 26, 2010, 09:37:41 AM »
My second tank on my Monster showing pimples now (center of pic) - I've had this new one for about 13 months now:
Reply #777 on:
August 26, 2010, 09:50:13 AM »
I find that my tank shrinks a bit if im on long trips where i fill up multiple times.
then i found out i can just shave my tank to get it look smooth again. my first attempt did not go so well. i will try again later.
you think they will reject me? They already approved and ordered my tank...
Reply #778 on:
August 26, 2010, 12:16:15 PM »
Quote from: He Man on August 26, 2010, 09:50:13 AM
LOL!!!
You crack me up
No, the tank's defect was presented and approved before the damage.
Reply #779 on:
August 28, 2010, 04:53:21 AM »
Added some research links to the first post. here they are:
The last PA6 note mentions that PA6 can absorb moisture to 8% of its weight, and that's from a manufacturer of PA6 parts.
Footnotes:
On Nylon 6/PA6
http://onlinelibrary.wiley.com/doi/10.1002/pola.1993.080310119/abstract
http://www.dsm.com/en_US/html/dep/akulonmoisture.htm
http://www.springerlink.com/content/h046820627255320/
http://www.zellamid.com/show.aspx?SP=2&url=202PA6
On Ethanol adsorption of water
http://www.springerlink.com/content/j2x43q45660x5617/
http://www.oregon.gov/OSMB/news/E10.shtml
51
52
53
54
191
