April 28, 2024, 01:37:44 AM
52
53
54
55
191
Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates (Read 678164 times)
Monstermash
AKA-TomColore
Interferiscalo se potete
Re: Plastic Tank problems: Sign up list and discussion.
Reply #780 on:
August 30, 2010, 04:09:07 AM »
Here's an interesting little tidbit of info for you guys....
I just got off the phone with Craig at Caswell. During my discussion he mentioned they have sold some of their fuel tank sealer to DNA for testing and that they were "very pleased" with the result. So I ask you, does that mean that DNA is planning on sealing our tanks with the Caswell sealer prior to shipping out the tanks for warranty replacement? That would make sense wouldn't it? Some people have mentioned having to have their tank replaced more than once and at over $2K per tank this has to be getting expensive for Ducati. I would think a $40 fuel tank sealer kit from Caswell would be a great way to insure that the replacment tank wouldn't have the same problem.
duccarlos
Reply #781 on:
August 30, 2010, 04:15:38 AM »
I'm not sure that the tanks go through DNA. From what I understood, they come straight from Italy to the dealer. DNA might ask the dealers to apply it. Some dealers are impossible to simply have them put in the warranty request, let alone ask them to apply an additional coating.
Reply #782 on:
August 30, 2010, 05:41:55 AM »
Quote from: Monstermash on August 30, 2010, 04:09:07 AM
The coating (or some coating very similar) would be applied at the time of manufacture. Even $40/tank is high. If it is possible to include it as the last stage of roto-molding, then the per-tank cost drops to materials only and probably absurdly cheap, esp compared to replacing the tanks.
Monstermash
AKA-TomColore
Reply #783 on:
August 30, 2010, 07:43:07 AM »
Quote from: ducatiz on August 30, 2010, 05:41:55 AM
Exactly. Also, the Caswell kit will do 2 almost 3 of our tanks so even though $40 is a lot for DNA or the dealer to absorb it would be less in quantity.
IMO Ducati should do something other than just keep replacing tanks becasue of the shitty fuel we are required to buy.
Greg
Reply #784 on:
August 31, 2010, 02:02:10 PM »
Tank update - San Antonio - After KCI closed shop with my new tank "on order", I finally visited the new Ducati dealership in San Antonio. I explained the situation with KCI and that the tank had apparently been OK'ed for a replacement previously, so they wrote it up and took more pictures to submit to DNA. They said they would be in touch with me as soon as they heard back from DNA.
Hopefully this time I will get a new tank, as the old one is really swelling bad and it's a pregnant dog to unlatch the tank.
2012 M1100 Evo with Termis
Reply #785 on:
September 02, 2010, 09:43:36 AM »
Quote from: Monstermash on August 30, 2010, 07:43:07 AM
<snip>
It seems they're doing the best they can...things take time and Ducati isn't going to spend whatever the cost to coat tanks until they have proof it will solve the problem.
Remember DNA doesn't design the motorcycle...just import and support.
I'm certain that this is costing everyone involved an everyone would like a permanent solution.
Why not talk to your representative about changing the regs regarding fuel?
J.P.
Reply #786 on:
September 02, 2010, 12:57:28 PM »
You're Right!
That does it, I'm gonna write a letter!
On a serious note, I found a source of ethanol free, 100 octane, low lead. Local airport. Runs great in the norton and doesn't dissolve the Fiber glass tank, but anyone know what it'll do to a s2r1000?
Last Edit: September 02, 2010, 01:00:06 PM by J.P.
'06 S2R1k- Have a nice day!
Reply #787 on:
September 02, 2010, 01:12:36 PM »
Quote from: J.P. on September 02, 2010, 12:57:28 PM
You're Right!
100 octane would most likely carbon up the duc
For $50 you can touch my
Reply #788 on:
September 02, 2010, 01:16:12 PM »
You're Right!
Low lead sounds uh, unhealthy....
csp808
Reply #789 on:
September 02, 2010, 03:05:34 PM »
You're Right!
Likely ruin your o2 sensor
rockaduc
Reply #790 on:
September 02, 2010, 11:19:33 PM »
You're Right!
Might cause dogs and cats to sleep together.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
Reply #791 on:
September 03, 2010, 03:20:15 AM »
You're Right!
probably get it impounded while you stay in jail.
$6.50/gallon near me. probably cheaper to coat the tank over the long run
Regular pump gas is $2.52 down the street. $4/gallon premium? the tank treatment is only $40.
duccarlos
Reply #792 on:
September 03, 2010, 04:31:44 AM »
Has anyone asked Caswell if we can get a good deal in a group buy?
Reply #793 on:
September 03, 2010, 04:47:57 AM »
Quote from: duccarlos on September 03, 2010, 04:31:44 AM
nope, i think they do sell it in larger quantities, problem is reshipping it. i imagine you could buy a bunch of the motorcycle kits tho.
J.P.
Reply #794 on:
September 03, 2010, 05:02:27 AM »
Lead and o2 sensor- maybe.
Note on caswell: applied it to the norton F-glass tank, must have missed a spot as the ethane fuel kept on attacking it, varnishing up the carbs,head. So application is very important, maybe employing a roto spinning jig thingie or something. The stuff does make a nice coating inside.
52
53
54
55
191
