April 27, 2024, 10:11:14 PM
59
60
61
62
191
Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates (Read 678080 times)
DeuceNYC
Re: Plastic Tank problems: Sign up list and discussion.
Reply #885 on:
October 13, 2010, 08:26:42 AM »
The EPA is running with a proposal to increase the allowable percentage of ethanol in gasoline from 10% to 15%. I hope DNA finds a workable solution soon because it seems the problem will only get worse.
Veloce-Fino
Wiggle-Jiggle
Bike sold - But I'm still lurking.
Reply #886 on:
October 13, 2010, 08:30:52 AM »
Quote from: DeuceNYC on October 13, 2010, 08:26:42 AM
The EPA
This is the problem right here.
Is this thing on?
Reply #887 on:
October 13, 2010, 08:32:12 AM »
Quote from: Veloce-Fino on October 13, 2010, 08:30:52 AM
let's not go there....
Reply #888 on:
October 13, 2010, 08:33:22 AM »
the only option is for EVERYONE to write the EPA and complain about it OR to ask them to mandate that pumps have to offer Ethanol-free gas as well.
duccarlos
Reply #889 on:
October 13, 2010, 08:39:18 AM »
Would this cause the issue to be worse than what it already is? I would assume that unless it increases by like 50%, it would still cause the issue at probably similar rate.
Reply #890 on:
October 13, 2010, 08:44:55 AM »
Quote from: duccarlos on October 13, 2010, 08:39:18 AM
Absolutely. It would accelerate the expansion. Ethanol absorbs water at a certain rate (pure gasoline does as well, but the rate is around 1/1000th that of ethanol).
Increasing the ethanol dilution by 50% means there is 50% more water in the mixture.
DeuceNYC
Reply #891 on:
October 13, 2010, 08:46:27 AM »
I don't think anyone knows for certain, but a 50% increase is pretty significant. Not to mention ethanol produces fewer BTUs per gallon than gasoline so you'll also be looking at poorer fuel economy.
Reply #892 on:
October 13, 2010, 08:51:47 AM »
We need a separate ethanol thread...
duccarlos
Reply #893 on:
October 13, 2010, 08:56:46 AM »
Agreed, yuu already started it. Guys, before everyone freaks out, they are increasing it by 5%. This means 5% more water absorbtion, which is technically 50% of the current level, so yeah I see your point.
Reply #894 on:
October 13, 2010, 09:13:31 AM »
Quote from: duccarlos on October 13, 2010, 08:56:46 AM
50%
corrected
10 ml of ethanol absorbs water at a rate of X per minute at Y degrees and Z% humidity.
15 ml will absorb 50% more by volume with X Y and Z remaining constant.
Increase the temperature and/or humidity and the absorption rate increases.
Kurt V
Reply #895 on:
October 13, 2010, 09:58:01 AM »
Quote from: ducatiz on October 13, 2010, 08:06:13 AM
Mine took 5 months.
Don't expect quick service on this, you are in a big line of people probably, esp for the popular colors.
That really is unacceptable. If that is the case, once it is fixed I will be selling it. I love the 696 Monster, but if that is the way Ducati wants to treat their customers, then I will vote with my feet.
Reply #896 on:
October 13, 2010, 10:08:47 AM »
Quote from: Kurt V on October 13, 2010, 09:58:01 AM
In my case, I have the '05 S2R Acid Yellow, which was the only year and model offered in that color, so I assume it was the rarity. As far as other delays, bear in mind there are a LOT of people making these claims now and someone actually has to look at the photos when they send them in.
Currently (I'm told by DNA that) dealers are communicating >directly< with Bologna with a new system they've put into place. I think that may speed things up, but it seems to me that DNA should have the say-so anyhow since they are the warrantor, not Bologna.
5 months is the longest I've heard, most are around a month.
duccarlos
Reply #897 on:
October 13, 2010, 11:36:01 AM »
Mine was less than 2 weeks. I think DNA has been doing a fantastic job turning these around.
CDawg
S4RS
Reply #898 on:
October 13, 2010, 11:36:30 AM »
Awesome...
Meerkat
When I'm not playing Silver Power Ranger, I'm a
Reply #899 on:
October 14, 2010, 02:41:07 PM »
Filed my NHTSA ODI complaint today.
'07 S2R1K
'09 Daytona 675
'03 620 Dark-Sold 03/26/2011
59
60
61
62
191
