April 27, 2024, 12:37:52 AM
65
66
67
68
191
Topic: Plastic Tank problems: Discussion thread, see info thread sticky for updates (Read 672518 times)
GAAN
Re: Plastic Tank problems: Discussion thread, see info thread sticky for updates
Reply #975 on:
November 15, 2010, 04:13:48 PM »
Quote from: Spidey on November 15, 2010, 04:10:55 PM
Huh? I'm confuzzled.
Yeah, I'm sober too
Reply #976 on:
November 15, 2010, 04:16:48 PM »
Quote from: Mother on November 15, 2010, 04:08:32 PM
yeah well maybe but still over 50 pages...
see, now that is a proper Derby
damn kids these days just don't take the time to do things right anymore
c u r r e n t...
cur·rent (kûrnt, kr-)
adj.
1.
a. Belonging to the present time:
DrDesmo
Reply #977 on:
November 15, 2010, 06:33:21 PM »
Not to get off topic, but it would appear that the "other" firm has gotten quite aggressive with Google AdWords, do a search for "Ducati Fuel Tank" and you'll see what I mean ...
Cheers,
Adam
'95 916
'12 800XC
corey
'06 Tang/Black S2R800
Reply #978 on:
November 15, 2010, 07:47:44 PM »
Not really going to be ANY opportunity to get a new tank if some schmuck sues Ducati into non-existence.
That's the last thing we need.
I understand there is some element of danger here with the tank expansion, but for pete's sake... it's still just a toy.
Bill in OKC
S4Rs
Reply #979 on:
November 15, 2010, 08:10:12 PM »
You would think that Acerbis would be aware of the problem by now wouldn't you? I've been reading about the new Aprilia RSV4 and guess who makes the tank for it - Acerbis - and the 2010 RSV4 tanks are having the exact same problem as the nylon Ducati tanks. I'm guessing a solution coming from Acerbis is not imminent.
'07 S4Rs '02 RSVR '75 GT550 '13 FXSB '74 H1E '71 CB750
Reply #980 on:
November 16, 2010, 02:49:00 AM »
Yea, we could tell from your thong wearing, dirt bike riding antics...
Reply #981 on:
November 16, 2010, 06:05:06 AM »
Quote from: Bill in OKC on November 15, 2010, 08:10:12 PM
They are aware. I know Ducati has been doing some testing and I can't imagine that Acerbis isn't doing it for them. The best solution -- I believe -- would be a coating similar to the Caswell that doesn't present a problem for them. Caswell works, but it affects their ability to homologate the tank for some reason. Seems they could find another compatible coating or surface treatment that doesn't have the same issue..
dvyce
Reply #982 on:
November 16, 2010, 06:40:59 AM »
I have not read the entire thread so guys pls forgive me if what i am about to ask has already been asked. Will this tank expansion issue affect all 696's? Cuz as we speak, mine is inside a crate, inside a container on some ship being shipped across the Atlantic and will arrive mid January. As for me, I have thrown the idea of seeing any type of dealer should this occur because we do not have any in Ghana. The closest bike dealer we have is KTM and that in the country next door. Anyway can someone please help me with my Q? Thanks a ton
Reply #983 on:
November 16, 2010, 06:44:00 AM »
Quote from: dvyce on November 16, 2010, 06:40:59 AM
It seems to affect all plastic tanked bikes when exposed to ethanol fuel.
The actual tank on the 696 is under skins so the effects may not be noticed as quickly as the earlier models.
sbrguy
Reply #984 on:
November 16, 2010, 07:34:01 AM »
Quote from: corey on November 15, 2010, 07:47:44 PM
unfortunately the company still sees the warranty route as an economically feasible solution otherwise they would have changed the plastic or what have you by now, but the cost benefit to them of waiting for a few people to try to return the tanks and such and after a 2 year stint its on you then, they are just hedging the numbers and figure that it will cost less to just do warranty repair as each tank is probably only really costing them maybe something like $10 dollars they are pressed out anyway.
if they get sued maybe they will then use differnt plastics and figure out the problem.
basically they have no reason to change the design as its not 100% of the tanks and so far nobody has been killed by the problem its really not that big of a liability.
Last Edit: November 16, 2010, 04:42:43 PM by sbrguy
Reply #985 on:
November 16, 2010, 07:44:13 AM »
I have several 696 owners on my list.
If your local gasoline has more than 5% ethanol, then you should look into getting the tank coated. There is a coating here called Caswell's which is (I believe) an epoxy based coating. Testing and actual use has demonstrated it works, however Ducati can't use it for other reasons.
Doing the coating yourself is easy if you have any experience with tools and have the right ones handy. Removing the tank isn't hard, you just have to take out the guts (filter, pump,etc) and remove all the metal and filler parts, then mask everything off.
One person I spoke to said coating the bottom of the tank is sufficient because the problem occurs at the bottom of the tank -- ethanol absorbs moisture and sinks. Since the volume of water is going to be less than 2% the total volume of gasoline, it's a very small contact area where water comes in contract with the surface (and also the hottest area of the tank -- heat + moisture = fast absorption)
Reply #986 on:
November 16, 2010, 07:45:31 AM »
Quote from: sbrguy on November 16, 2010, 07:34:01 AM
I don't know for a fact, but my gut feeling is that they are looking for a solution. I guess I'll find out soon enough.
sbrguy
Reply #987 on:
November 16, 2010, 07:47:28 AM »
it seems like so far the only thing that would work 100% is going back to a metal tank.
Reply #988 on:
November 16, 2010, 07:57:19 AM »
Quote from: sbrguy on November 16, 2010, 07:47:28 AM
Not possible. They would have to have the entire bike recertified and re-homologated. They can't/won't do it.
A coating is the most efficient and cheapest route. They just have to find one that is compatible with their EPA/DOT/EU requirements.
dark_duc
2008 S4RS Tricolore
Reply #989 on:
November 16, 2010, 11:32:49 AM »
Quote from: ducatiz on November 10, 2010, 10:04:48 AM
Good to know.
I think it's helpful for people to post up the names of shops that are doing right and wrong on this issue.
Everyone should get the same deal: bring your bike in (or send pics with the VIN info), tank ordered, bike brought in after tank arrives and swapped (and info verified if emailed). That should be the long & short of it.
Went to Hansen's BMW / Ducati / Triumph in Phoenix Oregon and had them look at my mildly deformed tank. They said they hadn't heard any issues with the Monster's tanks, but they took some pics and contacted DNA. They called me a couple days later to let me know that the claim was approved and a replacement tank was on they way. Once arriving they said they would only need an hour with the bike to do the swap. The crew at Hansen's made this a very easy process.
65
66
67
68
191
