February 04, 2025, 10:51:52 PM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: Steering Damper: side mount v. top mount  (Read 6029 times)
BumbleB
« on: August 17, 2009, 05:12:41 PM »
I have been checking the forum regarding steering dampers (thanks for the posts, especially Somegirl's review). I am narrowing down my decision, but am curious on any input regarding location. Would you recommend a side-mount unit or a top-mount damper?
Thanks for the input.
I'm not much for quotes - tell me what you know...
desmoworks
« Reply #1 on: August 17, 2009, 05:50:51 PM »
I personally like top mount for the look, ease of adjustability on the fly and it is more protected in the event of a crash. They both work though!
Anthony Creek
Pro Italia Online || mota-lab
xcaptainxbloodx
« Reply #2 on: August 17, 2009, 11:12:04 PM »
what about mounting under the lower brace?
S2R 800 '07
« Reply #3 on: August 18, 2009, 12:43:02 AM »
I've been told it works a lot better on the side.
It's more in direct/rigid contact with the parts it's damping.
Top mount kits have some flex in the brackets(?)
Also, the top mounts are shorter - maybe longer is better...
Looks on the other hand Roll Eyes
Norm
hurricanemotorcycles.com
« Reply #4 on: August 18, 2009, 05:23:09 AM »
Side mounts can damage the frame in a crash (FHE). I always use a transverse, under the triple design.
ducducgooseme
Same ole DesmoDevil, in a more gentle package
« Reply #5 on: August 18, 2009, 05:30:42 AM »
Having had a side mount come loose under normal driving, I will never mount one there again.
top mounts for me!
probably high-sided.
BumbleB
« Reply #6 on: August 18, 2009, 05:44:36 AM »
Thanks for the input...this helps! I'm seriously considering the Bitubo top-mount.
scduc
« Reply #7 on: August 18, 2009, 04:15:16 PM »
One problem that I see, is that if you ever go to an after-market top triple, you are pretty much stuck with going side mount. I know I've seen the under "brace" style, wish someone would post I pic. That is what I will go with if I ever get one.
xcaptainxbloodx
« Reply #8 on: August 19, 2009, 02:22:35 AM »
what is your setup?
Norm
« Reply #9 on: August 19, 2009, 04:10:21 AM »
I mount one end to the frame and the other to a clamp around the fork leg. You can weld or drill for a frame mount and then space it 'til it lines up with the leg mount. I can take some pics it that'll help.
Always make sure the adjustment is on the left side so can make changes on the fly.
DucatiTorrey
My wife's super hero is my
Industrial Designer
« Reply #10 on: August 19, 2009, 05:38:06 AM »
+1 i'd like to see that
  - real place
yotogi
« Reply #11 on: August 19, 2009, 06:33:29 AM »
+1 Could someone with a mount that is not top or side post pics?
S2R 800 '07
« Reply #12 on: August 19, 2009, 06:39:16 AM »
It's only for pre 2001, but to give you an idea
http://www.motowheels.com/italian/myproducts.cfm?parentcategoryid=123%7CDucati%20Suspension&productID=5412&showDetail=1&categoryID=126|Monster%20Suspension&vendoridtodisplay=0&filterFor=&collection=168%7CEuropean%20Motorcycle%20Parts
DucatiTorrey
Industrial Designer
« Reply #13 on: August 19, 2009, 06:44:55 AM »
oooh wya down there. hmm.
i like the top idea most. kind of sucks if i ever get a new top triple though.
maybe if i do the triple and the top mount at the same time?
  - real place
Norm
« Reply #14 on: August 19, 2009, 06:45:33 AM »
How do I post a pic?
Pages: [1] 2   Go Up
