February 04, 2025, 10:45:19 PM
Steering Damper: side mount v. top mount
Topic: Steering Damper: side mount v. top mount (Read 6028 times)
DucatiTorrey
My wife's super hero is my
Industrial Designer
Re: Steering Damper: side mount v. top mount
Reply #15 on:
August 19, 2009, 06:48:05 AM »
host it online with photobucket or flickr
then use the icon button up top to insert the url
- real place
truckinduc
Reply #16 on:
August 19, 2009, 05:38:45 PM »
hey norm, Im doing a very similar setup. The damper will be rearward of the bottom triple and the adjustment will be on the left. In my opinion its the best, Cleanest mounting place ofr it.
crazy bike girl
aka msincredible
Reply #17 on:
August 19, 2009, 11:58:35 PM »
Quote from: Norm on August 19, 2009, 06:45:33 AM
How do I post a pic?
http://ducatimonsterforum.org/index.php?topic=109.0
photo FAQ
Norm
hurricanemotorcycles.com
Reply #18 on:
August 20, 2009, 05:11:07 AM »
I know technology can be wonderful for those who can use it, but not me. I've used Photobucket before but now I can't seem to upload a pic (after spending much of yesterday just trying to log on).
I just took one crappy pic, but I'd like to post it as promised.
crazy bike girl
aka msincredible
Reply #19 on:
August 20, 2009, 05:56:07 AM »
Quote from: Norm on August 20, 2009, 05:11:07 AM
PM sent.
photo FAQ
sfarchie
Reply #20 on:
August 20, 2009, 02:12:34 PM »
Here's my setup for my 1100S. I love it! But I would recommend using something to protect your bike at the point of contact for the brackets. I took mine off recently and there were some scratches under it. Nothing big, buy if you're anal... And before anyone asks. No, it doesn't hit my knee.
Ray
SFaRChie
crazy bike girl
aka msincredible
Reply #21 on:
August 21, 2009, 07:57:35 AM »
Here is Norm's picture:
photo FAQ
BumbleB
Reply #22 on:
August 21, 2009, 10:50:36 AM »
Thanks for posting the photos...nice.
I'm not much for quotes - tell me what you know...
desmoworks
Reply #23 on:
August 22, 2009, 08:03:38 PM »
Quote from: scduc on August 18, 2009, 04:15:16 PM
One problem that I see, is that if you ever go to an after-market top triple, you are pretty much stuck with going side mount. I know I've seen the under "brace" style, wish someone would post I pic. That is what I will go with if I ever get one.
If you go with an aftermarket triple or just riser that is higher all you need is two spacers and two longer bolts for the Bitubo setup to work. Several people are running this setup.
Anthony Creek
Pro Italia Online
mota-lab
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Reply #24 on:
August 23, 2009, 06:08:30 PM »
Quote from: somegirl on August 21, 2009, 07:57:35 AM
Perfect
This is exactly how I'd like to install a steering damper on my m1100..... wish I could figure out how to make up a bracket for the frame end... hint, hint... any ideas?
Quote from: desmoworks on August 22, 2009, 08:03:38 PM
If you go with an aftermarket triple ...........all you need is two spacers and two longer bolts for the Bitubo setup to work. Several people are running this setup.
Um.... I'm running a speedymoto top-triple..... I dont follow you at all here...um..
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
pitbull03
Reply #25 on:
August 23, 2009, 06:16:04 PM »
If you've seen a pic and can direct me to it, that would be great. Thanks
M1100S
996
desmoworks
Reply #26 on:
August 23, 2009, 06:46:06 PM »
Quote from: ungeheuer on August 23, 2009, 06:08:30 PM
Perfect
Hopefully this is obvious, but it can only be done on a triple with risers... not a triple with clip-ons.
The new risers add (x)mm. Making the distance between the damper mount and its mounting point where the ignition switch is the difference between the original height and (x).
So if the original riser was 30mm and the new riser 45mm you'd need 15mm spacers and bolts that are 15mm longer than the original bolts in the mounting kit.
This will bring the damper mount up the same distance as the riser and it will work properly again.
Anthony Creek
Pro Italia Online
mota-lab
desmoworks
Reply #27 on:
August 23, 2009, 06:47:07 PM »
Quote from: pitbull03 on August 23, 2009, 06:16:04 PM
I don't have any images, but there is nothing to see besides two spacers under the U shape mount that goes around the ignition switch... the rest looks identical.
Anthony Creek
Pro Italia Online
mota-lab
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #28 on:
August 24, 2009, 02:07:28 AM »
I wonder if the fork-clamped bitubo damper kit could be made to fit beneath the bottom triple clamp in the manner that
Norm
has fitted up his damper??
Last Edit: August 24, 2009, 02:14:15 PM by ungeheuer
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Norm
Reply #29 on:
August 24, 2009, 04:32:20 AM »
For the frame mount, you can use a horn mount or install a rivnut (McmastersCarr). On the fork side, use a rivnut or a fork clamp.
