February 10, 2025, 11:36:12 PM *
Pages: 1 ... 6 7 [8]   Go Down
Author Topic: Performance suggestions for my S4  (Read 21432 times)
muskrat
« Reply #105 on: March 12, 2010, 06:44:07 PM »
must not look at this thread  bang head
you are costing me money!  BUT I likes.  Grin
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
fouramdesigns
« Reply #106 on: March 13, 2010, 05:56:46 PM »
Bikes torn down almost completely. Trying to figure out how to remove the throttle bodies to drop the motor.
So, here's what's on the agenda:
frame PC black
black mag Marchesini's
Fuel Cel- black w/Ducati 3D logo red
Motogadget M Unit fuse box, M switches, Motoscope/Sign gauge, m-Lock Digital remote ignition/starter lock
Nemesis ECU or a re-flash of the DP unit to delete immobilizer
Quat Exbox/ Boom Tubes
Spiegler brake lines   black lines/red banjos
LSL Rear set
LSL steering dampener
Rizoma handle bar/red
swing arm PC black
calipers etched black
new billet clutch set up/red pressure plate
CF headlight basket/mounts, trim ring PC black
clear headlight lens w/HID
LED smoked tail  light
Rizoma reservoirs brake red/clutch black
Rizoma bar end mirrors black
Rizoma grips black
2001 Monster S4, Termignoni/ECU, DP short air box w/BMC filter, Rizoma Zero's front/back, Cookie tail chop, Rizoma belt covers, Evoluzione slave, CF all over
tonkoshala
'02 S4
« Reply #107 on: March 13, 2010, 06:40:09 PM »
Can't wait to see it!  waytogo
What did you decide with the engine?
fouramdesigns
« Reply #108 on: March 13, 2010, 06:52:12 PM »
leaving it stock. See if I can get a Nemesis and dyno'd, coax a bit more out.
loves ze desmodromics.
« Reply #109 on: March 14, 2010, 05:58:46 AM »
You are going to run in to some difficulty in trying to do a CF headlight bucket AND a clear headlight lens. The DP Carbon Fiber headlight bucket is not compatible with the Desmoworld Clear-Glass Headlight (which is a complete headlight. You can still powdercoat the Desmoworld's headlight ring though. DDM HID kit fits fine in it as well. No problem with the CF headlight brackets though. I suggest PC'ing the U-bracket while you are there.
Pages: 1 ... 6 7 [8]   Go Up
