Performance suggestions for my S4
Started by fouramdesigns, February 02, 2010, 08:06:21 AM
fouramdesigns
Buying Quat D, best to move away from DP ECU? Power Commander, other?
2001 Monster S4, Termignoni/ECU, DP short air box w/BMC filter, Rizoma Zero's front/back, Cookie tail chop, Rizoma belt covers, Evoluzione slave, CF all over
tonkoshala
I say no. The DP ECU it bumps up the RMP rev limit. Same with the power commander. I bet someone has posted a base map with a similar setup to work from before you tune the bike on a dyno.
What did you decide on the handlebars?
Quote from: tonkoshala on February 20, 2010, 09:03:49 AM
the PC doesn't adjust the RPM limiter/fuel cutoff. the DP ECU does.
tonkoshala
Quote from: Raux on February 20, 2010, 09:08:03 AM
Where I meant same was to not move away from. Can see how it coulda been misleading...
fouramdesigns
If you are thinking about doing it, here's some more ideas:
Ferracci 984cc Kit (big bore/stroker): http://www.ferracci.com/store/cart.php?m=product_detail&p=196
Ferracci 955cc AMA Race Kit: http://www.ferracci.com/store/cart.php?m=product_detail&p=194
Ferracci Hi-Comp / 955 HC Pistons Only: http://www.ferracci.com/store/cart.php?m=product_detail&p=192
fouramdesigns
what kind of performance could expect from just the pistons?
Certainly a gain from high comp, a bigger gain from big-bore high comp, and something ridiculous from the 984cc.
The 955 is nice, but I'd make sure a competent engine builder does the work on any of the bore/stroke kits. There's been lots of favorable and unfavorable 955 discussions in the past.
Others will certainly be better equipped to discuss this. Also, give Ducshop a call, since they are 'nearby'
gage
I've heard mixed review on JE pistons... Pistal seem like the way to go.
The biggest big bore kit you can go to without the expense of boring the cases and the decrease in reliability associated with that is 933cc. You may luck out and already have the cases that can accomodate a bigger bore but there is no way to check other than to break it down.
gage
Quote from: fouramdesigns on February 24, 2010, 05:08:13 AM
I was told that HC pistons would be good for 8-12whp
Quote from: gage on February 24, 2010, 10:56:37 AM
You mean the 936 (ish... 935.8cc)? That's only 1 mm diameter bigger than factory bore. I haven't torn into a 916, but that seems odd.
foggy123
Buy a 996 motor it will be cheaper than a big bore upgrade.  St4s/s4r will work.  ~1k and you can still sell your motor.
Keep the bike upright also helps.
fouramdesigns
Quote from: foggy123 on February 24, 2010, 01:41:56 PM
Nice. I've made it through rain,. sleet and snow. Was a dry day, low tread on the front, and some road salt.
gage
Quote from: ato memphis on February 24, 2010, 11:02:09 AM
No I believe it is a straight 933 - this is a 1mm overbore - perhaps you lose the extra 1.4 cc per cylinder because of the Nikasil coating.
I was told this by several very reliable sources at performance engine shops and boring out the cases is a solution but costs big money
Interesting. I've never run across such a small over-bore Duc. Its like the 924 kit for 900cc Monsters and Supersports that was apparently available. (and quite dumb imo.)
