Performance suggestions for my S4
Started by fouramdesigns, February 02, 2010, 08:06:21 AM
tonkoshala
Quote from: foggy123 on February 24, 2010, 01:41:56 PM
Buy a 996 motor it will be cheaper than a big bore upgrade.  St4s/s4r will work.  ~1k and you can still sell your motor.
Keep the bike upright also helps.
Don't you have to install a single side swing arm?
Quote from: tonkoshala on February 24, 2010, 05:31:35 PM
there are ways around that.
Not if you use an ST or S4R 996.
The cases are different than SBK.
fouramdesigns
2001 Monster S4, Termignoni/ECU, DP short air box w/BMC filter, Rizoma Zero's front/back, Cookie tail chop, Rizoma belt covers, Evoluzione slave, CF all over
Quote from: fouramdesigns on February 27, 2010, 11:39:56 PM
How would I integrate these masters into my setup, they have a built in reservoir?
http://www.bigccracing.com/shop/product.asp?idproduct=43&source=thumb
Aren't they normal radial masters? Looks like it - meaning you'd need remote reservoirs.
fouramdesigns
that I cannot tell exactly from the pics, looks like no, from the pictures. I cannot find a website fore the company.
Those are standard radials. You have to use remove reservoirs. Never heard of the brand. Maybe look for Spiegler, ISR, Brembo, etc.
supertjeduc
I had some PT radials ,not good [evil] ,don't buy them
fouramdesigns
Quote from: supertjeduc on February 28, 2010, 08:46:00 AM
Thanks for the heads up. They look good, but if they don't function, it's just semi-art.
fouramdesigns
Well chaps, looks like the thumb doesn't want to play ball with the rest of the team, surgery tomorrow afternoon. Using k-wire if possible, plates if worse. Stinks all happens at once. Keep me in prayers, vibes, what ever your preference is.
fouramdesigns
Some good news at this point, DuckStew has my SBK front end done, and it's freakin gorgeous. Top notch work, he took my idea, and made it a reality. Man has vision. Too bad I'm gimped up, on STD, to complete at this moment. Very anxious to get this done. Good things take time, The Duc (Duke) will be a piece of artwork.
Mojo S2R
Nice  :o  I really like that front end  [thumbsup]
ducducgooseme
probably high-sided.
fouramdesigns
