GUN STUFF
Started by fastwin, June 26, 2010, 11:24:07 AM
muskrat
finally pulled the trigger on the Promag set up for one of my Mosin's.  Bipod and scope next.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
I like all the adjustment in that stock
muskrat
Promag has en for 200 but cheaper than dirt is at 139
2015 MTS 1200
09 Electra Glide
how do you scope it??
The Bearded Duc
Quote from: ducatiz on January 08, 2015, 06:54:34 PM
You gotta drill and tap the receiver.
There's an original PU scope that mounts to the left side of the receiver, this one requires cutting away part of the stock.
Some just remove the old slide sight and use the existing mounting holes.
The first two require a bolt with a bent handle so as not to interfere with the scope.
2001 M750 - Sold
muskrat
Correct you are Sir
2015 MTS 1200
09 Electra Glide
Quote from: The Bearded Duc on January 09, 2015, 12:05:48 AM
Its' a neat stock, but not exactly the most accurate platform to use with it.
Even if you got one of the Finn Mosins, you're still talking about a 120+ year old design.
I have a PU scope for one of my Sako Mosins and I use good ammo, but it is nowhere near as accurate as an average quality modern rifle with a heavy barrel.
Looks cool tho.
I have a Remington 788 in .308 that I'd like one of those for.  It's a great little rifle with some short comings but tack accurate.
Quote from: duccarlos on January 19, 2015, 08:03:02 AM
Why?!
"When a Tyrannosaurs Rex rampages through your neighborhood, this would seem to be the perfect tool for the job."
Or, maybe just...  Because they could. [evil]
ZLTFUL
Had a little bit of fun slingin' brass with my brother yesterday...
2012 Panigale 1199
2003 KTM 640 Adventure
Kopfjager
Kopfjager
#5863
I want to apologize to all the local rodents in advance. CZ 455 22lr Tacticool. It goes to the smith for some polishing and threaded barrel for the 'can'
Quote from: kopfjäger on January 19, 2015, 05:21:41 PM
Not sensing the fear...
;D
