January 01, 2025, 08:35:05 AM
The PCV with Autotune thread......
9
10
11
Topic: The PCV with Autotune thread...... (Read 56157 times)
Johnny5
Re: The PCV with Autotune thread......
Reply #135 on:
June 20, 2013, 07:23:51 AM »
Quote from: metroplex on June 20, 2013, 07:16:45 AM
If you remove the O2 sensors and closed loop operation, and just get a clean fuel map, how are you controlling the AFR during cruise conditions (essentially the range of cells in the fuel map that was previously controlled in closed loop) without Autotune?
Yeah I'm thinking since I have a good dyno guy close by that is a PC guru I would leave the AT out of the equation, just have him custom tune it with the PC5 after removing the O2 sensors from the map.
Sundad - Father and Son Acoustic fusion guitar trio
http://www.sundad.com
See us on Youtube -
Reply #136 on:
June 20, 2013, 09:10:08 AM »
The Rexxer builds a new map right onto the main ECU sans O2.
You can either have the tuner build the custom map on the rexxer if they have that capability, which few do, or you reflash with the standard Rexxer map and then customize the PCV for you bike.
it's not like the ecu is going to go haywire looking for the o2 to decide how much fuel. that's what the rexxer map fixes.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Reply #137 on:
June 20, 2013, 11:50:13 AM »
Quote from: Johnny5 on June 20, 2013, 07:23:51 AM
A good idea for
metroplex
too IMO (which I suggested to him days ago).
Quote from: Raux on June 20, 2013, 09:10:08 AM
And whilst this is true, its already addressed in other general ECU tuning threads.
You have already posted in the thread which answers this question mate. I suggest you read it. All.
http://www.ducatimonsterforum.org/index.php?topic=41934.135
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
wip3out8oy
Reply #138 on:
February 24, 2015, 08:13:08 AM »
Hello everyone, I'm new to this so I'll introduce myself a little bit. I'm from England and I've got a 2009 Monster 1100s (I do get it out when it's dry only, which is often
). I've done a fair bit of work to it most recently I've installed the Autonue kit with the PVC and had the stock ECU Rexxer flashed. I've also taken out the stock air intake box and replaced it with velocity stack pods (like the WASP PUK, it is infact the TPO Beast-R).
My question is, since the beginning of this thread does anyone have a suitably well configured AFR Table? Since this thread was started PowerCommander/Dynojet still haven't configured anything.
Any help would be great
2009 Monster 1100s | TPO Beast-R Air Intake Kit | QD slip on Exhausts | PowerCommander V with Autotune | Rexxer ECU Flash
EEL
Reply #139 on:
February 26, 2015, 05:38:16 AM »
I'll make it simple for you cuz I asked this same question 2 months ago.
Search for power commander autotune m1100 evo with me as the OP
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #140 on:
February 27, 2015, 12:31:01 AM »
Quote from: wip3out8oy on February 24, 2015, 08:13:08 AM
Yup, your setup is near identical to mine (although you don't mention what exhaust you're running).
Here again is the AFR table I arrived at (and have been happily running with for a couple of years (?) now:
https://drive.google.com/file/d/0B8GYk44zAjpmZGRiZjJkZmItZTIyZC00MTkzLTlkZjAtNjRhYTliOTA0ZTYy/view?pli=1
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Reply #141 on:
February 28, 2015, 04:48:53 PM »
Really enjoyed re-reading this thread.
Good work fellas.
technoracer
Reply #142 on:
May 01, 2016, 02:34:57 AM »
Quote from: koko64 on February 28, 2015, 04:48:53 PM
Good work fellas.
Same here! Just ordered the pcv and auto tuner. Excited to try Ung's map!
Has anyone bothered with different maps for each gear?
thanks again!
Last Edit: May 01, 2016, 02:37:49 AM by technoracer
'09 M1100
Akrapovic, MWR PUK, Rexxer, K&N, Open lid
EEL
Reply #143 on:
May 01, 2016, 05:12:36 AM »
i was planning that out this coming winter
technoracer
Reply #144 on:
May 04, 2016, 02:54:29 PM »
Quote from: EEL on May 01, 2016, 05:12:36 AM
Mapping by gear? It looks easy enough to set up...
Last Edit: May 05, 2016, 04:04:39 AM by technoracer
'09 M1100
Reply #145 on:
May 04, 2016, 02:56:27 PM »
Looking forward to hearing your results and impressions.
technoracer
Reply #146 on:
May 06, 2016, 01:37:01 PM »
Anyone happen to know offhand which of the 3 wires on the speed sensor we tap to enable the gear mapping on a '09 m1100?
'09 M1100
Reply #147 on:
May 06, 2016, 02:04:30 PM »
On line fitting instructions on PC site should have it via the links for that product.
Last Edit: May 06, 2016, 02:10:10 PM by koko64
technoracer
Reply #148 on:
May 06, 2016, 02:10:09 PM »
I'll look for them online. Thanks!
'09 M1100
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Reply #149 on:
May 08, 2016, 01:43:29 AM »
Quote from: technoracer on May 01, 2016, 02:34:57 AM
Remember, when your PCV is managed by the Autotune module...... Autotune creates the mapping dynamically.
With Autotune, 'ungs map' (or any 'map')... isn't one. It's merely the air/fuel lookup table from which Autotune constructs the best appropriate map for prevailing setup and conditions.
As far as I remember then..... 'mapping' per gear is gonna be neither possible nor necessary. Set your AFR x RPM x throttle % (as per the table I use or your preferred variation)... and let Autotune do the rest.
Or forget Autotune, wire up for geared mapping and have your Dynotuner create a static map for each gear..... if that's your thing.
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
9
10
11
