Looking for monster 800
Started by KTMracerx009, May 06, 2011, 08:53:11 AM
KTMracerx009
KTMracerx009
says there are carbon fiber fenders and covers, aftermarket sprocket
looking for $4000
What year is that 900?
If you can get and share bigger photos that would be great. But if it's a 2000 that might be a 900S.
The 900S was the only monster to come from the factory with a floating rear caliper. A give away is the linkage rod below the swingarm
The 900S had carbon huggers and side covers 3-way adjustable forks and an Ohlins shock. If it is an S it's a better deal than originally one might have thought
Quote from: Sad Panda on May 25, 2011, 12:00:44 PM
GOOD EYE
the third pic shows an under slung caliper with the con rod
zooom
I Emailed you the pics....
2010 KTM 990 SM-T
The other dead visual give away is that the Ohlins shock has an external reservoir - but I can't  tell from that photo. The angle and light make a dark spot where it might be. On a 900S it's mounted behind the shock on a bracket and is clearly visible from a lot of angles . On a base 900 the shock has no external reservoir
*edit* zoom sent me photos. It's a 900S for sure. There will have been a carbon rear hugger from the factory, so you might ask. But it is 2000 vintage CF so it's really not great by today's standards. Tended toward pun holes and yellowing
It's a better deal than thought. That shock would run you $800+ as an upgrade purchase currently
KTMracerx009
ok guys here is the question which is the better deal i have the cash for both of them
1. the 03 monster 1000 with 14k miles on it that was up on cragslist, he emailed me saying it is still for
2. the 01 900 that i posted a link too(the last one) he sent me the same pics that he later put in the craigslist add
they both are about $4000 so which is best? im probably buying one of them this week unlsess some freak disaster happens
depends on the condition in person.
everything can look great on paper
1000 and 900 are pretty close engines.. that's not a ds1000 is it?  if it is, that's a +1
The 900 is a year 2000. That's the only year the S model had that rear brake and Ohlins shock
KTMracerx009
Quote from: KTMracerx009 on May 26, 2011, 09:22:08 AM
his post says its a 2001 http://washingtondc.craigslist.org/mld/mcy/2401152158.html  before he put the pictures up
gotta look at it then.  might just be dumb.
KTMracerx009
yeah the 900 is only about a 20 minute drive but the 100 is about 3 hours away
The Mad King Pepe'
Quote from: ducatiz on May 26, 2011, 09:08:13 AM
I would put a +1 to the suspension (Ohlins shock and 3-way adjustable forks) on the M900 since there's more benefit in those than from and extra few ponies in the engine.
KTM, go and check them out this weekend. Seeing the bike in person is always different from looking at photos of it. Talk to the owner, try and get a sense of how they treat their bikes, how much do they know about them. Keep researching the bikes (what are the kbb values?) I think you might be able to talk down the price of a bike if you can show the owner that you're knowledgeable.
KTMracerx009
i am for sure looking at the 900 this weekend becasue it is close and depending on how that goes might go see the 1000 which is 3 hours away
tocino
Surely a tough call - same price and they both have lots going for them.
Carbs vs. FI - i <3 teh carbz but a good FI = fewer problems
900 vs 1000 - 900 is the classic Monster, but the 1000 is newer and it's the DS motor right?
Suspension - King Pepe has it right - good suspension is essential
The only negative to me on the 900 is why'd he change the color? I'm always suspicious of that.
So I'll echo what everyone else is saying: take a look at the 900 and if it's in good shape go for it. If he won't let you take it for a spin (I wouldn't :)) see if he'll take you for a ride around the block. Is it currently registered / titled?
If it's not 100% but close, you could check out the 1000 and possibly call the 900 guy and play the "well the one I'm looking at is 200 bucks cheaper? Any chance you can come down to 3800? I'll bring cash" game :)
