January 04, 2025, 08:59:29 PM *
Pages: 1 ... 5 6 [7] 8 9 ... 36   Go Down
Author Topic: Team UnorthoDUX Ducati based land-speed racers New pic pg 19!  (Read 225936 times)
Dirty Duc
I'd rather be an anti-
« Reply #90 on: March 08, 2013, 09:06:35 PM »
Kiss
I take it from your attitude you'll be there to help wash it for photo ops? Kiss  Tongue
OT
Still Sweeping.....
« Reply #91 on: March 09, 2013, 09:04:35 PM »
MY attitude?  Wasn't me who posted the scowling reply.
A little levity, boys, this is supposed to be fun, not the Lord of the Flies...
Dirty Duc
« Reply #92 on: March 09, 2013, 09:14:34 PM »
Sorry, the joking tone didn't come across...
It was intended to be levitatious.
« Last Edit: March 09, 2013, 09:25:18 PM by Dirty Duc » Logged
« Reply #93 on: March 09, 2013, 11:56:53 PM »
 Evil
sometimes i win without trying
« Reply #94 on: March 11, 2013, 05:26:41 AM »
Picked up a 749 fuel tank, a white GSXR front wheel (the super-skinny Honda wheel will go on later this season), an 848 cylinder head for air-flow research (2014 season) and a fiberglass 'Busa fender which will be easier to mod than the plastic OE fender we have in the photos thus far.
CLOSER....  & closer still!
JohnEE
Why not
« Reply #95 on: March 11, 2013, 06:15:52 AM »
Whats the plan with the exhaust? 749/999 OEM is under tail isn't it? It's Looking good!  waytogo
« Reply #96 on: March 11, 2013, 06:42:59 AM »
2x 50mm head pipes merging into a single 66mm pipe heading into a reverse cone megaphone exiting low mount on the right side.  Along the way, it picks up a wide band O2 sensor then a small pipe to scavenge windage from the crankcase.  The undertail OE design isn't needed for the ground clearances of salt flat racing so we ditched the OE style & all the additional bends...
ZLTFUL
WWSDD? Why Anal of course!
« Reply #97 on: March 11, 2013, 07:24:38 AM »
Besides...LSR bikes are required to be obnoxiously loud.  Evil
2012 Panigale 1199
2003 KTM 640 Adventure
zooom
« Reply #98 on: March 11, 2013, 07:52:26 AM »
I guess with that exhaust set-up, you shouldn't experience any issues of restrictive flow on WOT at the top end then?
2010 KTM 990 SM-T
« Reply #99 on: March 11, 2013, 07:55:54 AM »
the run up distance is long enough and the traction low enough to not have to worry about low end tq losses and be able to tune the system strictly for high RPM operation.
zooom
« Reply #100 on: March 12, 2013, 03:25:04 AM »
hey Stu, when you get to Bonneville, you should try and get an upclose look at this -> http://www.bikeexif.com/custom-indian-motorcycle?utm_source=feedburner&utm_medium=email&utm_campaign=Feed%3A+Bikeexif+%28Bike+EXIF%29
2010 KTM 990 SM-T
JohnEE
Why not
« Reply #101 on: March 12, 2013, 03:38:36 AM »
Mind explaining this part?
« Reply #102 on: March 12, 2013, 05:02:55 AM »
High velocity exhaust creates a vacuum which sucks out the aerated oil from the crankcase. That negative pressure allows the pistons to move around more freely.
Can't run that on a street bike as you're sucking aerated oil into the atmosphere. Road racing won't allow it either. Legal @ drag racing & Bonneville.
Totally not worth it in a street bike as I suspect it's only worth 0.5-1 HP at a maximum.
(if that much.)
« Reply #103 on: March 12, 2013, 05:29:13 AM »
(if that much.)
it's enough for the panigale to have a positive crankcase suction
« Reply #104 on: March 12, 2013, 05:34:12 AM »
Every bike with a breather connected to the airbox has that...no?
Pages: 1 ... 5 6 [7] 8 9 ... 36   Go Up
