January 04, 2025, 09:09:40 PM
Team UnorthoDUX Ducati based land-speed racers New pic pg 19!
7
8
9
10
36
Topic: Team UnorthoDUX Ducati based land-speed racers New pic pg 19! (Read 225953 times)
Re: Team Unorthodux 749R land-speed racer (My new wallet-hole) New pics pg 5
Reply #105 on:
March 12, 2013, 06:18:30 AM »
Quote from: ducpainter on March 12, 2013, 05:34:12 AM
Every bike with a breather connected to the airbox has that...no?
To an extent, yes. This is just amplified a lot...
zooom
Reply #106 on:
March 12, 2013, 06:34:34 AM »
Quote from: Duck-Stew on March 12, 2013, 06:18:30 AM
up to 11 ?!?!?!
2010 KTM 990 SM-T
Reply #107 on:
March 12, 2013, 06:38:05 AM »
I understand the amplification of the exhaust suction.
I was curious as to what the Panigale uses over and above the typical PCV system that Ducati has been using...forever.
Reply #108 on:
March 12, 2013, 06:41:58 AM »
maybe i was confusing the air induction pump system into the exhaust gases
Reply #109 on:
March 12, 2013, 06:47:37 AM »
Quote from: Raux on March 12, 2013, 06:41:58 AM
Not to jack Stu's thread...
ahh...a smog pump.
That's probably to reduce emissions while still running a map that will make power.
Dirty Duc
I'd rather be an anti-
Reply #110 on:
March 12, 2013, 06:51:44 AM »
Ah yes... it turns out the Panigale has a PAIR system. Not for better engine performance, but for better emissions performance. Apparently Ducati was finally required to catch up to the rest of the performance bike world by the inexorable march of the green people.
Ducatis on the Salt
JohnEE
Why not
Reply #111 on:
March 12, 2013, 08:19:14 AM »
Oh I see, interesting. Thanks for the info.
08' S2R 1000
Reply #112 on:
March 12, 2013, 08:34:51 AM »
Got the tank installed, but it's too dang big...
Fortunately for me, it's Ducati's last steel tank used on a superbike so I can cut & weld it as needed. Here's the projected first cut (just above the blue tape):
From there, a new bottom plate will need to be water-jet cut and welded in. Going to run a later model Ducati in-tank pump as they're cheaper than the 749/999 units & flow more fuel.
The best kind of whore is a
Reply #113 on:
March 12, 2013, 05:01:09 PM »
Quote from: Duck-Stew on March 12, 2013, 05:02:55 AM
High velocity exhaust creates a vacuum which sucks out the aerated oil from the crankcase. That negative pressure allows the pistons to move around more freely.
Can't run that on a street bike as you're sucking aerated oil into the atmosphere. Road racing won't allow it either. Legal @ drag racing & Bonneville.
Totally not worth it in a street bike as I suspect it's only worth 0.5-1 HP at a maximum.
(if that much.)
Does this actually do anything? Id buy it if it were on a single but on a 90° twin when one piston travels down the other moves up and there's a balance of air pressure.
No?
Reply #114 on:
March 12, 2013, 05:16:30 PM »
If it were a boxer twin, then you'd be right. Because it's a 90' twin, there is some overlap where they're both coming down.
Honestly, I doubt it'll do much. But, ram air @ 190mph going into the air box will be creating positive pressure so this is my fix...
Reply #115 on:
March 12, 2013, 05:18:34 PM »
190 mph solves all kinds of problems
Dirty Duc
Reply #116 on:
March 12, 2013, 06:07:33 PM »
Quote from: Duck-Stew on March 12, 2013, 05:16:30 PM
Actually it would work better on the BMW boxer. They are 180 degree cranks. If I ever get another one, I'm going to re-phase one of the cams to make a big bang engine.
Ducatis on the Salt
Reply #117 on:
March 12, 2013, 06:09:56 PM »
Quote from: Duck-Stew on March 12, 2013, 08:34:51 AM
~~~SNIP~~~
~~~SNIP~~~
From looking at the side view of you on the bike, I'd say you'll need to channel/section that dude about 3".
cokey
hey take a look @ my
Reply #118 on:
March 12, 2013, 08:05:11 PM »
Is there a reg on tank size? Couldn't you fit a smaller tank just for enough fuel?
I WIN
Quote from: my wife
Ok babe I surrender to u. U may work me out till I drop
About the goat...
Dirty Duc
Reply #119 on:
March 12, 2013, 09:34:47 PM »
Quote from: cokey on March 12, 2013, 08:05:11 PM
5 liters.
not a lot, but more than just enough.
Ducatis on the Salt
7
8
9
10
36
