April 28, 2024, 10:58:31 PM
CAM
CAM track day anyone?
8
9
10
Topic: CAM track day anyone? (Read 15581 times)
Omnipotent Potentate
Personal Pretext
Re: CAM track day anyone?
Reply #120 on:
June 12, 2013, 09:42:05 AM »
Quote from: JoeP on June 12, 2013, 09:23:40 AM
at myself,
Why laughing at yourself?
JoeP
Reply #121 on:
June 12, 2013, 10:30:23 AM »
Quote from: Slide Panda on June 12, 2013, 09:42:05 AM
The vid showed that I need to work on looking farther ahead and scoping out lines better. I'm saw myself doing a lot of shaky course corrections as a result. Also saw places where I turned in too early on a double apex corner and wound up running wide. All good, just trying to get better and have fun doing it.
Personal Pretext
Reply #122 on:
June 12, 2013, 10:33:37 AM »
Gotcha - your course corrections weren't as bad as that dude on the R1 who binned it the day before. He was weeble wobbling all over the place
zooom
Reply #123 on:
June 12, 2013, 11:17:54 AM »
Joe, you didn't look as bad as the R6 in the end who was trying to force himself past Ian in a couple spots and overcooked it badly....
2010 KTM 990 SM-T
JoeP
Reply #124 on:
June 12, 2013, 04:48:40 PM »
Quote from: zooom on June 12, 2013, 11:17:54 AM
Yep. I have enough self control to back off when I know I can't pass safely. But, I did target fixate on R6 dude when he ran off so I blew that same turn. Another lesson learned!
ducFrank
Reply #125 on:
June 14, 2013, 10:11:09 AM »
What are you guys talking about? There was no one on the track!
2005 Ducati 749S track only
2009 Ducati 1100S - bent frame
Personal Pretext
Reply #126 on:
June 14, 2013, 10:15:19 AM »
Eh? Talking about that video I posted. What are you talking about
ducFrank
Reply #127 on:
June 17, 2013, 07:01:43 AM »
Some video of me... Constructive critique accepted
xsephirot
Reply #128 on:
June 17, 2013, 07:54:07 AM »
Quote from: JoeP on June 12, 2013, 10:30:23 AM
Glad you can pick out what you are doing wrong. If I may chime in.
I want to point out that you need to work on only 1 steering input per turn. At 2:58 for example, it looks like you are steering it to correct your line. Once you have the bike turned, you open that throttle right away (I noticed some areas where you were waiting for a second or two longer than yo needed to as if you were waiting to hit the apex of the turn before opening the throttle). If you find yourself going wide, hold that throttle at the position (do not close, resist the survival instinct) and your line will close. Similarly if you find yourself turning in too early, continuing rolling on the throttle until your line opens up and hold it to tighten it back to the apex. This may not seem like much as slower speeds but once you get comfortable going faster it's the only way to not upset the suspension.
Personal Pretext
Reply #129 on:
June 17, 2013, 08:15:08 AM »
That turn at the top of the hill after the bridge, the one referenced, is a giant pain in the ass though. The line one should take, and the one it looks like you should take are very different. The GoPro flattens it out, but the outside has a dip and is negatively cambered, so it spooks a lot of folks - but its where you need to go to set up for the next turn, which sets you up for the two lefts down to the straight. So we see (or don't see due to my wheel) Joe trying to stick it inside on that 180 degree left - getting flummoxed and then losing the drive down the hill.
But yes, watching this I see a few mid turn steering inputs that aren't needed
JoeP
Reply #130 on:
June 17, 2013, 04:27:30 PM »
Quote from: xsephirot on June 17, 2013, 07:54:07 AM
Quote from: Slide Panda on June 17, 2013, 08:15:08 AM
Good observations. Thanks! Watching Frank's vid, I notice how he tips the bike in and holds it-- one big input at the beginning and on the gas early. That's what I need to try for. There were a couple of times when I thought I would run wide and instinctively tried to slow down with a light touch on the brake, which resulted in... running wider. Next time I'll work on keeping a steady throttle and adding lean.
venomousr1993
Snapping Like a Squirrel
Reply #131 on:
June 17, 2013, 06:48:03 PM »
Anyone up for VIR North in July with NESBA??? July 15 and 16 each day 99.00 for elite members...not sure what it is for the peasants though.
Should be a good time...I check in to my new job tomorrow and it should be fun to see my new boss's face when I drop all my track days and race schedule in front of him for approval...lol
WERA Expert #163
Leo Vince
http://www.leovinceusa.com/
Lucas Oil
http://www.lucasoil.com/
WoundedWear
http://www.woundedwear.org/
AXO
http://www.axo.com/us/
ducFrank
Reply #132 on:
June 18, 2013, 03:43:35 AM »
Quote from: venomousr1993 on June 17, 2013, 06:48:03 PM
I totally WANT to do this... weekdays are hard because I have no real leave time right now and have to balance "my" off time with the "family" off time.
The Mad King Pepe'
Reply #133 on:
June 18, 2013, 05:53:46 AM »
Quote from: ducFrank on June 17, 2013, 07:01:43 AM
YOU SUCK!
Just kidding!
You seemed to be doing pretty well until about the 6 minute mark, then you looked more sloppy: was that tiredness kicking in?
ducFrank
Reply #134 on:
June 18, 2013, 06:24:41 AM »
Quote from: The Mad King Pepe' on June 18, 2013, 05:53:46 AM
YOU SUCK!
Just kidding!
It was the latter part of the second day... my legs burned... and i was exhausted. I ran this session short and the next two even shorter before throwing the towel in for the day. My body was done. lol.
8
9
10
