February 26, 2025, 09:53:04 AM
Homemade mods
5
6
7
23
Topic: Homemade mods (Read 300402 times)
forFREEDOM
Re: Homemade mods
Reply #60 on:
April 16, 2011, 06:16:32 PM »
i dyed my gray polymer parts black... it was pretty easy.
http://www.ducatimonsterforum.org/index.php?topic=43500.0
I also got a sweet nylon black ARMY motorcycle jacket for Xmas. One sleeve is digi-camo and looks odd to me, so I'm going to attempt to dye that black. I'll let you know how it goes.
Last Edit: April 16, 2011, 06:35:42 PM by forFREEDOM
cyco
Re: Homemade mods
Reply #61 on:
April 27, 2011, 11:43:58 PM »
Has anyone made own holders (rear sets) for the fotpegs and muffler ?
Im thinking about doin my own with stainless steel iron rods instead for the aluminium ones.
Need some input
Last Edit: April 28, 2011, 01:27:53 AM by cyco
forFREEDOM
Re: Homemade oil cooler guard
Reply #62 on:
May 03, 2011, 10:20:25 AM »
Quote from: bergdoerfer on April 29, 2011, 01:46:39 PM
just a quickie on a CNC router, powdercoated by the toothless old skinny guy down the road for a dollar
Very nice! Want to sell them? I'd buy one.
Spidey
Crashin' mofo
Re: Homemade mods
Reply #63 on:
May 04, 2011, 11:17:49 AM »
Stock clutch cover, cut and painted. Removed the gasket and then used washers as spacers between the cover and the case.
Exhaust Hanger. Metal tube. Cut to length, flatten the ends and drill holes for bolts.
Last Edit: May 04, 2011, 11:25:22 AM by Spidey
peerke
Re: Homemade mods
Reply #64 on:
May 07, 2011, 09:28:16 AM »
Complete carbonfibre tank with custom airbrush:
Skyshadow
'01 Monster 750 Dark
Re: Homemade mods
Reply #65 on:
May 07, 2011, 07:46:52 PM »
That tank and airbrush looks sweet! Really like the Monstra on the back. Where did you get the tank?
- Homemade Exhaust
- K&N filter
- Tail chop w/ integrated tail light
- Sliders
Quote from: cupcake on February 19, 2012, 04:53:56 PM
My rear brake is just for looks.
peerke
Re: Homemade mods
Reply #66 on:
May 07, 2011, 10:42:56 PM »
I made it my self
Skyshadow
Re: Homemade mods
Reply #67 on:
May 08, 2011, 10:03:13 AM »
Was it hard? Details...
- Homemade Exhaust
- K&N filter
- Sliders
peerke
Re: Homemade mods
Reply #68 on:
May 08, 2011, 11:03:13 AM »
Its verry hard work.
If you pull to hard on the fibre you will stretch it to hard and the pattern wil disapear.
I made it from 1 single piese of fibre.
Then 8 layers of hardner.
Sanding about 6 hours!!
Then 6 layers of clearcoat.
Custom airbrush
Again 4 layers clearcoat.
Only problem is that carbonfibre contains oxygen.
With the harder you will see little holes in the toplayer.
I have that problem now.
It must harden for some weeks and then again sanding.
Last 5 layers of clearcoat and the tank is 100% finished.
If you buy it its to ugly.
The fibre are al small pieces and you can see that.
This is the original:
Because i have 1 piese i dont have the little squares in the tank.
Its a lot of work , but it will save you about €1250,- thats $1760.- !!!!!
Here they cost €2500,- ($3521.-)
Again sorry if i made some spellings faults hahahha
My English typing is nog verry good
Last Edit: May 08, 2011, 11:05:41 AM by peerke
Scooter-Trash
Re: Homemade mods
Reply #69 on:
May 17, 2011, 11:51:25 PM »
Quote from: DoWorkSon on April 16, 2011, 01:28:05 AM
Installed an old oil cooler from a m750 on my 696... First of it's kind and only
I have yet to see.... Did it for under $100 compared to the $400+ that dp charges... And it works perfect.
I did the same thing with an old 900ss oil cooler on an '01 M900.
It turns out the aluminum gets really brittle after about 15 years. Be warned, it may spring a leak
Anchorism
Fast and Agile
Re: Homemade mods
Reply #70 on:
May 30, 2011, 10:45:53 AM »
Just did a temporary wrap on my forks using a 1" wide vinyl. Also, pulled off the extra oil cooler plastic air duct, and re adjusted my Tall boy clip ons.
"Life's tough. Its even tougher if your stupid!"
-2011 Ducati Monster 796
-1985 Moto Guzzi V65TT
Knobby tires
suzyj
Does my bum look big on this?
Re: Homemade mods
Reply #71 on:
June 05, 2011, 01:27:15 PM »
A123 LiFePo battery. I bought the cells off ebay, and put them into a holder made by a guy locally.
Then I cleaned up the starter wiring, with 4ga cable.
Easy way to lose a few kilograms. The stock battery is full of lead!
scduc
Re: Homemade mods
Reply #72 on:
June 18, 2011, 01:46:01 PM »
Quote from: suzyj on June 05, 2011, 01:27:15 PM
You may want to do a write up on this in the tutorials. I am interested in making a pack for my self, but would really like some more info and history. Pros and cons.
P.S. it looks awesome. What did you wrap the cables with?
08' S2R 1K That was close damn near lost a $400 hand cart.
rene 250
Re: Homemade mods
Reply #73 on:
June 28, 2011, 06:29:05 AM »
Quote from: peerke on May 08, 2011, 11:03:13 AM
Custom airbrush
liar liar pants on fire...
lawmaster891
Re: Homemade mods
Reply #74 on:
June 28, 2011, 09:14:28 PM »
cover i made out of the stock for my stepdads 748
5
6
7
23
