December 28, 2024, 05:39:40 PM *
News: Please Help
Pages: 1 ... 8 9 [10] 11 12 ... 14   Go Down
Author Topic: Motogadget loom project  (Read 61076 times)
DucHead
No garage queens
« Reply #135 on: October 16, 2014, 11:27:57 AM »
Did you mean *is*?
Yikes!! I did mean "is!"  ...will edit.
thump
« Reply #136 on: October 28, 2014, 01:09:23 PM »
Looks like your project is still progressing nicely.
My Motogadget tiny finally arrived, they sent it by slow boat I think. It's awful pretty though.
Did you end up using those Deutch connectors for those speedometer wires or did you solder directly to the loom, ie hardwired to the bike and not removable?
How are the deutch connectors otherwise in terms of being weatherproof, etc? I was thinking of cleaning up some connections behind my headlight now that it will be more exposed behind this little speedometer, so I'm looking for smaller connectors and to remove what is no longer needed.
Fun autumn project ahead.
My toolbox is full of hammers. Because the world is full of nails.
2003 M800 dark
ducatigirl100
« Reply #137 on: October 28, 2014, 05:19:29 PM »
 I've solder  the tiny , tiny .... well very tiny wire's from the motoscope  to some bigger wire's   after that I've crimp them to used a Deutch connector.  'I've put a rubber  protector over the soldered wires.   After that, from the conecctor ....I've soldered some Y connections to the original loom
I got myself an extra control button to control the fonctions on the motoscope and I've istalled it in the hole on the top yoke .  After a couple of month's of use I must say that it's andy  to have it there
« Last Edit: October 29, 2014, 03:27:50 AM by ducatigirl100 » Logged
ducatigirl100
« Reply #138 on: October 29, 2014, 03:26:45 AM »
popcorn we whant picutres!!
Deutch connectors are not that big I've sean bigger type of connectors and smaller ones to ... but tje Deutch arr easy to work whit.   There's a couple of good vids on You tube that describe how to use them waytogo
thump
« Reply #139 on: October 30, 2014, 04:56:49 AM »
Thanks for the helpful tips and pics. I got started yesterday after studying and drawing out the wiring for a bit. I'm no electrician so that took awhile. First step was to change the stock triple clamp, get rid of the old gauges and the resistors on the LEDs that I no longer need thanks to the m-flash. Once I get the flashers working again I've got to cut a bracket for the tiny speedo.
Since I'm not changing the whole loom as you did I need to clean up some wires behind the headlights cuz they're no longer going to be hidden behind gigantic gauges.
Hmm. Maybe figuring out how to upload a photo should be my next task. Off to create a photobucket account.
2003 M800 dark
thump
« Reply #140 on: October 30, 2014, 05:39:01 AM »
Here we go.
The bike:
The problem:
Stuff pulled off:
New triple clamp, much cleaner.
That's all I got so far, but it's a start. I'm thinking of mounting the tiny slightly off centre on the triple, towards the right.
2003 M800 dark
ducatigirl100
« Reply #141 on: October 30, 2014, 05:48:27 PM »
That look's geat  waytogo
 popcorn
For the moment I've tuck most of the wires behind the stering stem between the air box
MotoPsycho
General Nuisance and a
My Dream, my rules !
« Reply #142 on: October 30, 2014, 05:53:04 PM »
Since I never used the switch your left index finger reaches on the backside of the switchgear for the headlight flasher
("your bright lights are on idiot!" switch), I used that for the function switch for my motoscope. It failed eventually so I run a baby toggle next to dash.
Feral 859
« Reply #143 on: October 30, 2014, 07:54:39 PM »
« Last Edit: October 30, 2014, 08:02:59 PM by kopfjäger » Logged
ducatigirl100
« Reply #144 on: October 31, 2014, 04:45:52 PM »
 waytogo those's hare.very nice  drool popcorn
thump
« Reply #145 on: October 09, 2015, 11:13:02 AM »
Hi Ducatigirl,
Just a quick thanks for your help regarding the tiny. I put up a few pics of the end result, here's how she looks now:
The tiny is sitting just above the right headlight. Works perfectly, with the stock speedo sensor no less!
Much appreciated.
2003 M800 dark
SpikeC
Spike in PDX
« Reply #146 on: October 09, 2015, 03:03:16 PM »
Very cool result!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
ducatigirl100
« Reply #147 on: October 11, 2015, 01:17:56 PM »
Hi Ducatigirl,
Much appreciated.
waytogo drool
ducatigirl100
« Reply #148 on: April 13, 2016, 03:09:19 AM »
Ok... time to do this old tread a favor  popcorn
It all began I I was  inspecting the valves clearence ......
than my husband enterd the room and said  " You migth as well redoo the head and change your old piston rings"....... In my opinion he was tired of riding whit me and breathing the distinctive puff of smoke  and the burn oil smell fragrence of my bike ..... laughingdp
it goes like this.....
ho what the heck....
I migth as well change the valve seal...
I migth as well clean the cumbustion chamber
I migth as well overhaul the heads
I migth as well change the rings
I migth as well change the base head  gasket
and .....why not ........redoo the entire motogaedget  loom   Grin
« Last Edit: April 13, 2016, 03:38:05 AM by ducatigirl100 » Logged
ducatigirl100
« Reply #149 on: April 13, 2016, 03:22:14 AM »
Here a couple of pics of the mayhem   popcorn
Pages: 1 ... 8 9 [10] 11 12 ... 14   Go Up
