December 28, 2024, 06:08:24 PM
Motogadget loom project
8
9
10
11
14
Topic: Motogadget loom project (Read 61078 times)
ducatigirl100
Re: Motogadget loom project
Reply #120 on:
October 04, 2014, 07:17:55 PM »
After a first trial a couple month ago I fugure out a couple of desing "flaws"...
The loom was working properly but it didint add the"professionnal finish" that I add in mind
So I put it in a box . That just a "first draft" of the box just to get the proportion/desing whrigt . The pupose of the box is that I dont want anything to come in contact whit the wires to reduce the risk of short... and it looks cleaner
Last Edit: October 05, 2014, 02:59:01 PM by ducatigirl100
thump
Reply #121 on:
October 05, 2014, 07:08:18 AM »
Nice. Where did you plan to mount that when it's done?
Did you find the stock speedometer sensor worked with the motogadget gauge, or did you need to use their sensor?
My toolbox is full of hammers. Because the world is full of nails.
2003 M800 dark
ducatigirl100
Reply #122 on:
October 05, 2014, 07:59:23 AM »
Quote from: thump on October 05, 2014, 07:08:18 AM
After trials and errors ... the best place to put it is at the back under the seat where the old fuse box used to be.... it's important to keep it away from the heat of the motor.....
the wires will pass into the frame to go all the way up front just behind the stering
I use their sensor , I've empy out the gearing that was in the original speedo at the weel... drill a hole in the speedo spacer... and fit the motogadget sensor in it ... And put sillicon on top so it's all sealled
I'll take a few photos today ... but after using that speedo for a couple of months I really works nicelly
Last Edit: October 05, 2014, 02:34:26 PM by ducatigirl100
ducatigirl100
Reply #123 on:
October 05, 2014, 09:57:26 AM »
The funiest thing is that one of my friend bougth the motorsope tiny... he as a monster and he ask a guy that is cutomising is bike ( I wont name him, ha has a reputation in Quebec ) said that it was imposible to put the speedo at front weel becose ther was no place for it .... my friend said ok and they put the speedo at the back weel...
You sould have seen the face of my frind when he saw that I did it and the well known customiser guy coudnt
So here it is ...
The magnets hare place in one of the brake disk bolts ..the hole fits just whrigth... I've put 2 magnets on top of one another to get the whrigth distance so the sensor could pick up the signal
Last Edit: October 05, 2014, 02:36:23 PM by ducatigirl100
thump
Reply #124 on:
October 05, 2014, 10:18:44 AM »
Yup, there's a grim satisfaction when you can do something the professionals can't. Nice clean work there. So you just fit the magnet inside the hexagonal opening of a rotor bolt? That would be a happy coincidence! I'll wait until my kit arrives and see what I'm faced with before I shower you with more questions.
Thanks for posting the pics so quickly!
2003 M800 dark
ducatigirl100
Reply #125 on:
October 05, 2014, 10:28:19 AM »
Quote from: thump on October 05, 2014, 10:18:44 AM
Yes , tha magnet fit just whrigth I did enven add to put some epoxy glue on them
they wont budge from there!!!
When I'm gona change the disk brake in the future ... I'll just take a big magnet to take them out of there
Last Edit: October 05, 2014, 10:39:26 AM by ducatigirl100
ducatigirl100
Reply #126 on:
October 05, 2014, 10:30:58 AM »
Just tring out to get a sense of size and fitting ... Yepp.... that LFX-18A1-BS-12 shorai battery will fit..
But my 5.5 " box is a little bit big... I'll surch for a 5" box .. that area is 6" wide
and yepp ! That one of my air clips on the helmet older... when I take of my helmet I still wana look pretty
Last Edit: October 05, 2014, 02:40:18 PM by ducatigirl100
ducatigirl100
Reply #127 on:
October 06, 2014, 07:01:33 PM »
I've just got myself a cicuit box at my local electronic store....
I've put the M-Unit in it ..
All the wiring whit the connectors are tuck away under the m-unit
There will be 5 wires that will come out of it
1-ignition
2- battery +and -
3- front headlight/ signals
4- tail ligth / signals
5- motorscope tiny wire
I've made all the soldering , Y connections , 1A fuses, M-lock backup capacitor are in the box. At this point it's almost plug and play
Last Edit: October 07, 2014, 09:14:36 AM by ducatigirl100
ducatigirl100
Reply #128 on:
October 06, 2014, 07:17:56 PM »
I've also got some multi strand wires so those 5 links will be comprise in one wire for each
MotoPsycho
General Nuisance and a
My Dream, my rules !
Reply #129 on:
October 06, 2014, 08:03:17 PM »
Now what happens when you have to take the brake rotor off?
Got the 2nd part of the drawing done ? I'm curious to see.
ducatigirl100
Reply #130 on:
October 07, 2014, 04:03:52 AM »
Quote from: GRUBBY on October 06, 2014, 08:03:17 PM
For the disk brake I'll take a big magnet . There not glued there so they can move . They will stick to the big magnet when I'll put it in front ... tried and tested
The second part of the loom starter/ battery/ voltagr regulator/ ignition mudules, coils will come in a week or two.
Last Edit: October 07, 2014, 04:09:31 AM by ducatigirl100
monsta
Perth, Australia.
Reply #131 on:
October 07, 2014, 03:03:01 PM »
DucHead
No garage queens
Reply #132 on:
October 10, 2014, 05:18:09 AM »
Spieglerusa is a trustworthy source of motogadget goodies as well.
Last Edit: October 16, 2014, 11:28:21 AM by DucHead
"45"
Rudemouthsky
Autonomous red and black
No gods and no masters
Reply #133 on:
October 10, 2014, 07:36:36 AM »
Quote from: DucHead on October 10, 2014, 05:18:09 AM
Spieglerusa isn't a trustworthy source of motogadget goodies as well.
Did you mean *is*?
ducatigirl100
Reply #134 on:
October 12, 2014, 06:35:21 AM »
Quote from: monsta on October 04, 2014, 04:30:16 PM
I have a motogadget dash.
I cant get my low fuel light working.
They say to use a resistor, which I have tried. But no joy
I also tried a variable resistor (potentiometer) to try and dial in the correct resistance, still no joy.
You being a guru and all dg100... maybe you have some ideas?
Here's the answer
I dont know if it was the one that you used ?
A 82 Ohms, 5w resistor.... it seams that Ducati usally use a reserve indicator base on a thermistor...
I found the info ont the motogadget site
Th problem may origin from the sensor itself
Last Edit: October 12, 2014, 12:51:33 PM by ducatigirl100
8
9
10
11
14
