M944SS build
Started by Rudemouthsky, May 15, 2014, 07:15:25 AM
Scoober1103
09 M1100 + stuff.
07 GSXR750 stock as a......
15 KTM Freeride 250r for hurting myself!
Quote from: koko64 on April 02, 2014, 02:52:23 AM
Don't buy cheap shit, it can cut your balls off.
Rudemouthsky
Rudemouthsky
Scoober1103
Damn that is nice mate. Looking forward to some assembly pics of this beasty. All the bits accruing are just teasing the crap out of us!  ;D
09 M1100 + stuff.
Rudemouthsky
went up against this ugly basti'd...
Talked dirty to it the whole time
so much better
tackled the tach swap...this wasn't frivolous money, I had a NOS dash from an S4 with an ECU controlled tach, I needed to do this to even use it
went in without a fight. Swapped the indicator lights for red LED's while I was in there
Cleaned up my precious...she's still so purdy...can't wait to put her on when Speedog finishes putting the Matris carts in my forks.
Bought this today...it's a Mikuni DF62-702, the dimensions are the same as OE and the flow rate is similar.
But it has 2 outlets...I'm going to use a Y connector like this
and hopefully all will be well? I dig that it matches the OE one 'cept for being black. If it works out I'll be somewhat of a useful pioneer for something other than things to NOT do around here. :P
Quote from: Buck Naked on June 09, 2014, 08:56:02 PM
Cleaned up my precious...she's still so purdy...can't wait to put her on when Speedog finishes putting the finally receives the shipment of proper parts from Italy to allow the Matris carts to be installed in my forks.
Fixed it for ya.  :P
Rudemouthsky
Quote from: Speeddog on June 09, 2014, 10:08:12 PM
Fixed it for ya.  :P
haha, gotcha. Those Italians sure aren't in a hurry.
memper
Quote from: Buck Naked on June 10, 2014, 06:03:35 AM
Shiiiit. You ever been there? Itals start working at like 10 then take a siesta fer like 2 hrs then mosey on back to work with a buzz for a couple more hours to then go back to the cafe after "work"(at least Florence was like this before the euro).
lazylightnin717
Florence was still like that in 07/08 when I lived there
and the rest of Italy
Comes a time
Says don't you see
Gotta' make it somehow
Rudemouthsky
The Italian solution: Pirelli rubber on Carrozzeria forged aluminum
Rudemouthsky
Carrozzeria sent me the wrong front wheel!! I didn't notice until now that I have 5 rotor mounting points instead of 6.
And I already ordered my front axle...for an S2R800, which is forks I already have and the wheel I was supposed to get...
Does anyone know if 1100/796/S4R front wheels are even compatible with the 25 mm S2R 800 forks?? :(
5-bolt wheels are set up for a separate axle spacer on both ends.
Really, they're rings that run on seals in the wheels as well.
So the axle is different, and has an additional spacer on the right side, and a different spacer on the left side.
The S2R800 axle will work with the S2R800 forks.
The unknown at the moment is what configuration of spacers the Carrozzeria wheel is set up for.
It doesn't have the additional seals, well, at least on the one side in the pics.
What brake rotors do you have?
Rudemouthsky
Quote from: Speeddog on June 12, 2014, 01:22:58 PM
The rotors I have will not work. And it sounds to me as if my front speedometer won't work, nor will the S2R800 axle I just ordered.
Rudemouthsky
By the way thanks for that info Speeddog. You've already told me enough to know that I won't be using this wheel.
